2014 F250 4x4 6.7 only 13.7 MPG PLEASE HELP!!! - Ford Powerstroke Diesel Forum
post #1 of 28 Old 06-25-2014, 03:04 AM Thread Starter
Hi to everyone!
I'm new to the site and this might've been already posted but I'm still learning to navigate through here. Anyway, I'm new to having a Powerstroke. I recently switched from owning a Cummins and in March I purchased a 2014
4x4 6.7. Crew Cab. As excited as I am to have this truck I am only getting 13.7mpg. It has a leveling kit with 35" Nitto Trail Grappler M/T's. It has 3.55 gears. Otherwise it is all stock. Is this normal??? I have buddy of mine that has the same truck and he is getting 18mpg on his readout. I know that the readout is not always accurate but I just can't seem to make sense of how some are doing so well with their fuel mileage and I am not. I don't drive like a mad man just normal. I have considered a programmer but I'm not sure if I should buy one or not. I just want to have better MPG'S! Can somebody or anybody tell me what the heck is going on??? Any help would definitely be appreciated. Thanks!
hydrospec2001 is offline
post #2 of 28 Old 06-25-2014, 04:39 AM
Cheap6.7's Avatar
That's what I get with mix highway-town driving, I have a cclb on 35s. If you delete people have seen 3+ mpg.
Buy American!
Cheap6.7 is offline
post #3 of 28 Old 06-25-2014, 07:43 AM
It should get better as you get some more miles on it. Your big tires are not helping the mileage. The more stop and go you have the worse mileage you will get. I am probably not telling you anything you haven't heard. With my 2013 Dually, I am getting about the same mileage around town. I have the 3.73 gears.
RDUB is offline
post #4 of 28 Old 06-25-2014, 11:51 AM
ucpa111's Avatar
Quoted: 2 Post(s)
15.78 mpg overall on my truck 28,000 miles. worst tank was 11.9 and best was 20.4. All logged at each fill up and using excel to calculate. I commute 8 miles to work. The high MPG tank was flat driving and 90% interstate at 70 mph. Hills, stop and go, and cross winds take mileage down (that and a lead foot).
I am happy with my mileage. I have considered different tires (more aggressive) but don't want to sacrifice highway attitude and mileage.
My truck CCLB, 2012, 3.55, 20" stock with Michelins
2012 F350 CCLB 3.55 ELD with 20s. Lariat package, Chrome, FX4, Clearance Lights, Rapid Heat, Two Tone, Upfitters, HD Alternator, 5th Wheel prep, Truxedo Lo Pro Tonneau. Linex. On board air and shocker XL train horns.
THIS THING ROCKS!
ucpa111 is offline
post #5 of 28 Old 06-25-2014, 12:00 PM
The more stop & go and short-trip driving you do, the more your truck will go into regeneration or will attempt to regenerate. This KILLS your fuel economy.
My 2013 normally gets around 12 mpg in City driving with lots of short trips. When the regeneration process starts, it will drop to 10-10.5 and won't improve until the regeneration process is complete. If you turn your truck "off" before the regeneration is done, it will start the process again, when you start your truck (and it reaches the required temperature for regeneration). Turn your truck "off" again, before the process is done and you get to start over again. It can be a vicious cycle!
I did the full delete & tuner on my truck and averaged 12 mpg in City driving. Out on the highway, cruising at 75 mph on flat ground, my full delete wasn't any better than with everything "stock" - 17.5 to 18.5 mpg.
All my numbers are hand-calculated, so they are accurate, unlike the truck's mileage computer.
The 2013-2014 models are typically getting 2 to 3 less mpgs than the 2011-2012 models. It is my understanding that when Ford changed the programming from 2012 to 2013, they choked-down even more on emissions.
It's going to take 8,000 to 10,000 miles or more for your motor to loosen-up and start getting it's optimum fuel economy.
One last note: I went from 10w30 semi-synthetic to 5w40 full-synthetic oil and lost .5 to 1.0 mpg. When I went back to the 10w30, the mileage jumped back up. I wouldn't have believed oil could make that much difference, if I hadn't seen it with my own eyes.
Truckmaniac is offline
post #6 of 28 Old 06-25-2014, 12:04 PM
My truck specs are nearly the same as yours. My overall average mileage hand calculated and tracked in Excel is 16.1 MPG.
joeyou is offline
post #7 of 28 Old 06-25-2014, 12:14 PM
Quoted: 4 Post(s)
I also see better mileage with 10w-30 vs 5w-30. My truck has 20k miles with a lifetime average of 15.3 mpg.
Sent from AutoGuide.com App
Deerhunter4 is offline
post #8 of 28 Old 06-25-2014, 12:20 PM
I just did my first oil change at 5k miles, and I'm seeing the same thing. I went with 5W40 T6 Rotella, and in the couple hundred miles since the change, my mileage is down about 1MPG. I believe I'll be going back to 10W30 T5 next change.
I'm like you - never would've believed that oil would have made that much difference.
2014 F350CCSB 4x4 6.7L PSD
jsaund22 is offline
post #9 of 28 Old 06-25-2014, 03:14 PM
Originally Posted by hydrospec2001 View Post
Hi to everyone!
Hydrospec:
Welcome to the website Sir!
Like you, I have a new 2014 Ford Super Duty Lariat 6.7 also having come out of a 2006 Dodge CTD CR Pickup. Fortunately, I am averaging around 15.5-
16.5 with about 3,500 miles on the truck so far. But, as the other members pointed out, I still have the stock wheels and tires and IMHO those tires are probably affecting your mileage some. I "hand calculate" my mileage but on my 2014 the computer in the truck is pretty close to my hand calculations.
I am also using the "Ford Cetane Improver" Additive every tankful although I can't say whether that is making alot of difference.
John_P
2014 Ford F-250 Super Duty, 4WD, Crew Cab, Lariat Ultimate, FX4 6.7 "Scorpion" Turbo Diesel
John_P is offline
post #10 of 28 Old 06-25-2014, 07:38 PM
chrispy243's Avatar
Hydro, welcome and congrats on the powerstroke.
Can u give some specifics on driving condition, road conditions, environmentals etc.. Autonomous engine analyzers and computers can only go but so far to eliminate external variables and most importantly "the human element". Your 13.7 mpg means many different things depending on a great # of variables. All diesels have differen power bands, it will take some time for you to harmonize with the querks and characteristics of the powerstroke. Cummins and power strokes, both very good engines, and both behave differently. Do some testing and record your results. You will find her sweet spot.
15' F250 6.7L Platinum 4x4. Black on Black
13' F150 5.0L Lariat 4x4. Retired
08' F250 6.4L Lariat s.crew 4x4 6k hid, recon full led upgrades. 35" bfg all terr. "Retired"
99' Jeep Wrangler 35" bfg mud's, 4.56 locked front & rear, warn 9.5ti, etc.
chrispy243 is offline
