Sloppy PMF adjustable trac bar. Anyone else? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 17 Old 06-21-2014, 05:07 AM Thread Starter
2013F250Tank's Avatar
I installed a Precision Metal Fabrication front adjustable trac bar a year ago. Now there's slop where it connects to the frame. It seam like its the removable bushing. Worn out after a year?! anyone else have this bar installed?2005-2012 Ford F-250/350 Direct Replacement Adjustable Trackbar
13 F250 Lariat CC SB 3.31 EL axle w/SPE full lock module, Ultimate Interior,
H&S Big Single 64mm NON VGT Turbo Kit, Cast manifolds, NON Cobra downpipe, Mini MAxx w/H&S stock fuel tune
Down Pipe back 304T 4" Diamond Eye, AFE stage II intake, front 4 link,
Road Armor bumpers front/rear. N Fab nerf steps. 20" American Force w/Trxus 33",
Dura flaps, Air Lift rear bags, 34k+ miles, Stage 3 traction block bars.
2012 F250 TOTALED.
Civilian Contractor Airforce 2+ years Asscrackistan.
2013F250Tank is offline
post #2 of 17 Old 06-21-2014, 05:19 AM
I almost bought one. Glad I didn't. It seems the one from Ready Lift is the best one if you want something that won't ever fail.
lizardking is offline
post #3 of 17 Old 06-21-2014, 05:34 AM Thread Starter
i have a bunch of rattling coming from my front end i think its the PMF track bar and the non grease able 4 link. hope trevor helps
2012 F250 TOTALED.
post #4 of 17 Old 06-21-2014, 06:10 AM
Slacker
Evil Eye's Avatar
Quoted: 158 Post(s)
Feedback Score: 4 reviews
The bushing will wear out regardless of manufacturer. It should last longer than a year, though. Have you tried calling Trevor to let him know about your issue?
Shawn Carlson
EvilEye@powerstroke.org
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #5 of 17 Old 06-21-2014, 07:09 AM
Alberta Advantage's Avatar
Quoted: 18 Post(s)
I had a similar issue with mine. Actually ended up replacing it with another OEM unit as I had a significant amount of play and some clunking issues. Tried changing the bushings that Trevor sent me and still had the same issues. Trevor was helpful in trying to remedy the situation but nothing seemed to work that he advised the dealership's mechanic to do. I eventually gave up and went back to OEM and haven't had any issues since. I have the PMF trackbar sitting in my shed.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #6 of 17 Old 06-21-2014, 07:21 AM
ZMANN's Avatar
Quoted: 936 Post(s)
the ready lift unit is nice nice and $$$
anyone contact Trevor ?
https://www.gofundme.com/2464axqr
We Miss you Ronnie
RIP
ZMANN is offline
post #7 of 17 Old 06-21-2014, 10:31 AM
I've always heard good things about the PMF track bars, with that solid 1'' rod end bolted to the ball joint on the axle I would imagine even more stress would be put on that upper bushing mounting it to the track bar bracket. Give him a call or PM him on the Powerstrokearmy, name is NotStock. He's a busy guy but I'm sure he'll straighten out the issues. Good luck.
jordan572 is offline
post #8 of 17 Old 06-21-2014, 11:04 AM
Quoted: 18 Post(s)
Trevor (PMF) is also on this site. Same username, Notstock and is also in the vendors area too. He was a pleasure to deal with but unfortunately, I had to remove his trackbar as I had other issues after installing it. Once I replaced it with another OEM unit, my issues seemed to be resolved. I still have his draglink on my truck though.
Putco Window Visors
Line-X
Bak Flip F1
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
4" Solstice Prime
Truck Bed Lights
post #9 of 17 Old 06-21-2014, 11:05 AM
ZMANN's Avatar
Quoted: 936 Post(s)
He uses the same name here
EDIT Alberta A beat me to it LOL
We Miss you Ronnie
RIP
ZMANN is offline
post #10 of 17 Old 06-21-2014, 11:10 AM
My bad, I just never see much of him on here, mostly on the army.
