Fuel leak - Ford Powerstroke Diesel Forum
post #1 of 1 Old 02-09-2014, 08:08 AM Thread Starter
Fuel leak
I changed the fuel filters on my 2012 and noticed that fuel is leaking out of the lower filter(frame rail filter) housing. The fuel appears to be leaking out of the 32mm nut on the filter housing. It must have cracked when breaking the housing loose. Called the dealership and they want to see it before they will say if the filter housing is covered under warrenty or not. Its going in on monday, just curious if anyone had similar issues, and if it ended up being covered by warranty. Thanks
2012 F250 6.7 Lariat FX4
Western Plow
Firestone Ride Rite helper springs
Powerstop Drilled and Slotted Rotors, Carbon Ceramic Pads
Tmvjep is offline
