The Best One Inch Lift? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 27 Old 02-08-2014, 08:16 PM Thread Starter
POWERCHOKER
Dantron's Avatar
I've decided to go all out and lift the front end of my truck by 1 inch. I'm not sure which method I should use. I'm thinking about a BMC Spacer from PMF Suspension. What options do I have and which one is the best?
2005-12 Ford F-250/350 BMC Spacer
Dantron is offline
post #2 of 27 Old 02-08-2014, 08:58 PM
Your still bothered by the back end being level aren't you? Have you tried adding about 6 50 lb bags of sand to your bed? That way you will get a better ride and get a chance to see if you like the way it sits
Brett
"Stroker 8" likes this.
2013 F250 CCLB FX4 4" PURE PERFORMANCE
2013 F150 FX4 LEVELED 285'S
2001 F350 7.3 CCLB ZF6
rustyshakelford is offline
post #3 of 27 Old 02-08-2014, 09:44 PM Thread Starter
POWERCHOKER
Dantron's Avatar
Yeah I swear these trucks must be designed that way. Like if you were able to lay the truck body on the ground, it would look as if it were leaning forward slightly. I don't know. I would rather have a slight upwards rake than a slight downwards rake. I thought about using a few 1/4 inch spacers, but I highly doubt going with one full inch would be too much for what I'm wanting to do. Also, after my 37x13.5x20 Toyo's run out of tread, I'm switching to 38x13.5x20 Toyo's, so the extra inch of lift in the front can help ensure that I won't have any contact issues.
Dantron is offline
post #4 of 27 Old 02-08-2014, 09:52 PM Thread Starter
POWERCHOKER
Dantron's Avatar
Here are pictures of what I'm talking about...
ID:	240578   Click image for larger version
Dantron is offline
post #5 of 27 Old 02-08-2014, 10:46 PM Thread Starter
POWERCHOKER
Dantron's Avatar
I'm unsure on which type of spacer to go with...
Top Mount Coil
Ford Top Mount Coil Spring Spacer
Bottom Mount Coil
Dantron is offline
post #6 of 27 Old 02-09-2014, 02:19 AM
Big_Smokey's Avatar
the cheapest one you can find.
A spacer is a spacer in my experience with leveling kits. Im sure someone will disagree with me, but thats my opinion.
Truck looks good the way it is. ID rather have an inch of rake though if thats all you have. Soon as you put your boots in the bed you are going to be level again.
Big_Smokey is offline
post #7 of 27 Old 02-09-2014, 02:42 AM
Ontario Trucker's Avatar
[QUOTE=Dantron;8170890]I'm unsure on which type of spacer to go with...
Top Mount Coil
I like the top spacer, just my .05
Gerry..... 2006 F350 Lariat, white
Ontario Trucker is offline
post #8 of 27 Old 02-09-2014, 04:31 AM Thread Starter
POWERCHOKER
Dantron's Avatar
Another option I have is to get a smaller block in the back. That way I'll maybe have a slight increase in bed accessibility...
Ford Fabricated Lift Blocks
I still have more contemplating to do, but I definitely want to do something.
Dantron is offline
post #9 of 27 Old 02-09-2014, 05:09 AM
"Stroker 8"'s Avatar
Quoted: 3 Post(s)
If you have an F-350 and decide to remove the rear block's, I will be happy to take them off your hands.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #10 of 27 Old 02-09-2014, 05:20 AM
fordtrix's Avatar
I think it looks great as is. Love the wheels/tires/lift combo. Not fond of the tail light guards, however. I think removing them would make it look cleaner. Just my preference. More is better sometimes!
2013 F250 Lariat CCSB - Firestone Ride Rite, Bakflip F1, B&W 5th Wheel Hitch, Carli 2.5" with track bar, Fuel Maverick 20x9, Toyo MT 35x12.5, Bushwhacker Extend-A-Fender, Weathertech Mats, Recon 3rd Brake and Mirror Lights, PTM Mirror Caps
2013 Crossroads Elevation 3912 - Loaded
fordtrix is offline
