Wish Her Well - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 13 Old 02-07-2014, 06:30 AM Thread Starter
Devildog1's Avatar
Wish Her Well
Truck just went under the knife. Made the trek from WV to Rudy's Diesel in Durham, NC for an EGR and DPF Delete and Flo Pro Straight Pipes. Will have it back later today!
2003 F350
Bulletproofed
MBRP 5'
SCT Livewire
CTS Insight
Devildog1 is offline
post #2 of 13 Old 02-07-2014, 07:00 AM
Hope everything works out well for ya.... Everybody on here that has gotten it done sure seems to be satisfied
KENNY
2013 F250 Platinum Tuxedo Black
3.5" Ready Lift
Firestone Air Bags
20x10 BMF Novacane DMB
35x12.50R20 Toyo MT
kennyketten is offline
post #3 of 13 Old 02-07-2014, 07:07 AM
POWERCHOKER
Dantron's Avatar
Godspeed...
Dantron is offline
post #4 of 13 Old 02-07-2014, 07:40 AM
"Stroker 8"'s Avatar
Quoted: 3 Post(s)
You Lucky Devil! What Tuner did you go with? Are you having a Pyrometer installed at the same time? Looking forward to hearing your feedback. BTW, have a safe trip and be careful going home, you've awaken a sleeping Giant you know!
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #5 of 13 Old 02-07-2014, 07:51 AM
I want to delete SO bad! Just can't muster up the nerve to loose the warranty on a new $55K truck! I have the turbo surge issue as well. If I knew for sure deleting would cure the surge issue I'd go ahead and delete it pronto! Subscribed!
highmileage is offline
post #6 of 13 Old 02-07-2014, 08:52 AM Thread Starter
Devildog1's Avatar
mini max and yep on the pyrometer. Should be a fun trip home!
2003 F350
Bulletproofed
MBRP 5'
SCT Livewire
CTS Insight
The Following User Says Thank You to Devildog1 For This Useful Post:
350ninty7 (02-08-2014)
post #7 of 13 Old 02-07-2014, 02:21 PM
So. Fing. Jealous.
2012 F350 6.7L SRW LB CREW LARIAT ULTIMATE FX4 3.55 ELSD - SCT X4 - DELETED - 4" SS FLO PRO - NO LIMIT EGR DELETE
2012 FORD EXPEDITION EL LIMITED
2007 F350 6.0L SRW LB CREW XL FX4
2007 RANGE ROVER SUPERCHARGED
1970 FORD TORINO COBRA 429
fosterelli is offline
post #8 of 13 Old 02-07-2014, 04:17 PM Thread Starter
Devildog1's Avatar
Awesome!
Wow. I thought my built 04 was sick. 6.7 is so much smoother and more low end now. Sounds great as well
Rudy's went above and beyond the call of duty. From my first fact finding interaction with them followed by the purchase of parts and finally the install. Stayed beyond closing to ensure it was done right and I was was comfortable with operating the tuner. Well worth the 5 hour trek.
2003 F350
Bulletproofed
MBRP 5'
SCT Livewire
CTS Insight
post #9 of 13 Old 02-07-2014, 04:42 PM
ucpa111's Avatar
Well?! Grin factor of???? Pics????
2012 F350 CCLB 3.55 ELD with 20s. Lariat package, Chrome, FX4, Clearance Lights, Rapid Heat, Two Tone, Upfitters, HD Alternator, 5th Wheel prep, Truxedo Lo Pro Tonneau. Linex. On board air and shocker XL train horns.
THIS THING ROCKS!
ucpa111 is offline
post #10 of 13 Old 02-07-2014, 05:12 PM
steelnc's Avatar
They have been doing my work for the last several years. Great people and great service. Only 30 minutes down the road too.
2014 F250 Platinum
4" Pure Performance lift
20x10 Novas 35" Toyos
Mini Max
5" Flo pro
steelnc is offline
