Rancho dual steering stabilizer - Ford Powerstroke Diesel Forum
User Tag List
 1Likes
post #1 of 15 Old 02-04-2014, 05:21 PM Thread Starter
<<---"Shadow"---
sea71's Avatar
Hey fellas, where are you buying your Rancho dual steering stabilizer kits? $174 shipped is best Ive found. Thanks.
Shane
2011 F250 Crew Cab FX4
STOCK!
sea71 is offline
post #2 of 15 Old 02-04-2014, 05:23 PM
ZMANN's Avatar
Quoted: 554 Post(s)
i would really check out top gun customz and maybe spring for the bilsteins http://www.topguncustomz.com/
search them on ebay if you want a good price
https://www.gofundme.com/2464axqr
We Miss you Ronnie
RIP
ZMANN is offline
post #3 of 15 Old 02-05-2014, 06:56 AM
I just ordered a pmf dual setup for 299.
2012 CCLB F250 Lariat 4x4 6.7L
Rigid Industries 20" E-Series-Husky Liners-S&B Intake
Pure Performance 4" Triple Threat-PMF Dual Steering Stabilizer-Method NV-315 70R18 Toyo M/Ts
5-0stank is offline
post #4 of 15 Old 02-05-2014, 09:15 AM
Carli has a nice setup but I think it's a single
Brett
2013 F250 CCLB FX4 4" PURE PERFORMANCE
2013 F150 FX4 LEVELED 285'S
2001 F350 7.3 CCLB ZF6
rustyshakelford is offline
post #5 of 15 Old 02-23-2014, 05:43 AM
jluv's Avatar
Quoted: 4 Post(s)
I just gave my Rancho dual steering stabilizer to my mechanic instead of throwing it in the trash. I hated it. He said he'll either give it away or trash it, too.
First of all, no matter how tight you crank down the U-bolts in the center, the bracket still eventually moves down and rests on the track bar, binding it up and causing the steering to stick and fight to move. It makes driving extremely dangerous and unpredictable, especially at highway speeds. It would dance all over the lane. Plus, I'm pretty sure it led to the premature wear and demise of my steering box, hydro boost, and pump. All had to be replaced soon after running that poorly designed stabilizer for a while. I removed it as soon as I got home from a long road trip and realized what was happening. Called Rancho and they sent me a new set of U-bolts, exact same as what I had.
Then a Jeep guy I work with explained that this is pretty common, and the Jeep guys will spot weld the U-bolts to the axle to keep the bracket from shifting.
So just yesterday, I decided to reinstall the stabilizer and have it spot welded. Put it on and drive around the block. It takes time for it to shift, so I wasn't worried about it happening immediately. This gave me time to test drive it and see if I really wanted to keep it before I had anything welded.
Within just a short trip around the block, I came home and yanked it off. Even when performing properly, it makes it to where you have to turn the wheel back to center after a turn. The wheel doesn't come back on its own. That gets old very quick.
I am leveled with 35, and my stock setup isn't really sloppy or wobbly without this unit, so I work till be replacing it with anything else. Maybe it would work better in a situation where you have giant tires and your bumpsteer is bad. I just can't handle having to always put my steering wheel where it needs to be. I expect it to return to center on its own after a turn.
Anyway, this is just my experience. Yours may be better. Good luck!
jluv is offline
post #6 of 15 Old 02-23-2014, 05:48 AM
Ordnance on coordinates
powerstrokeshellback's Avatar
Quoted: 38 Post(s)
Feedback Score: 7 reviews
i got zone offroads for 175, their main bracket is nice and beefy but the fitment is total crap. if your lift uses drop anything instead of aftermarket it wont fit right. they dont mention that on the site, just says must have 2in or more. i emailed them so hopefully they will fix it.
2007 Ford F-250 XL 6.0L Powerstroke 4x4
God bless America, the Constitution and the Second Amendment.
Archoil gangbang - don't be the soggy biscuit
powerstrokeshellback is offline
post #7 of 15 Old 02-23-2014, 06:04 AM
Carli'd6.7's Avatar
Feedback Score: 6 reviews
Brett
that's the one yall need to be looking into , especially if ya run Toyos
**14 F-350 CCLB Lariat w/ HIPS !!**Sinister EGR kit** 4 inch Flow-Pro w/ 36" Magnaflow** H&S XRT PRO w/ SPE Heavy Tow Tune**AFE Stage 2**H&S CAC Kit**Edge CTS gauges**ICON stage 3 2.5 w/ tubular radius arms & 4 inch blocks**4.30 Yukons w/ Trutracs**Firestone ride rites**BW turnover**N-Fab cab Lengths**03.5-04 PSD Badges**20" Fuel Maverick Duals**Mag.Hytec Covers**
Carli'd6.7 is offline
post #8 of 15 Old 02-24-2014, 11:04 AM
OCVeloMan's Avatar
Quoted: 103 Post(s)
Garage
Steer clear of white body stabilizers. As mentioned above, if you're wanting a dual "opposing" style setup, it's best to find one with 5100 bilsteins. The white bodies have no separation between the oil and nitrogen, for lack of a better visualization, they're the equivalent to lava lamps inside. When you lay this shock on its side, gravity wins everytime and the oil goes to the bottom and nitrogen to the top. This means, at any given time, your shock piston is only half submerged in oil, thus, there is no damping happening at all, only cavitation.
This is why we use a single unit with a IFP (independent floating piston) with a custom valving profile. There is a LOT of technology in our little shock, full Stainless Steel Body, black Nitride shaft, billet rod end and half inch spherical bearings. The back section of the shock where the shrader valve is located is a small nitrogen chamber that puts pressure on the piston that separates the oil and nitrogen keeping the piston submerged in oil at all times and pressurizing the oil to prevent cavitation and ensure no fading during continuous abuse. The nitrogen chamber is also adjustable to correct for Toyo's right hand pull as well.
Dave likes this.
OCVeloMan is offline
post #9 of 15 Old 02-24-2014, 11:32 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 6 Post(s)
Dan any chance Carli will be making one for the 05-07s?
Email: Dave@powerstroke.org
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
http://www.bulletproofdiesel.com/default.asp
http://nolimitfabrication.com/
Dave is offline
post #10 of 15 Old 02-24-2014, 11:33 AM
OCVeloMan's Avatar
Quoted: 103 Post(s)
Garage
God i hope so... You guys have seen what i do to my truck and I'm 80K of hard miles on my factory POS. I'll poke Sage again but it's always been a back burner project.
