Oil Flush NEEDED??? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-02-2014, 12:03 PM Thread Starter
Oil Flush NEEDED???
Next oil change going to synthetic. Do I need to flush system with desired synthetic, for instance put it in run for several minutes then drain and put new in or is it ok to just drain the conventional, refill with the synthetic and call it good
KENNY
2013 F250 Platinum Tuxedo Black
3.5" Ready Lift
Firestone Air Bags
20x10 BMF Novacane DMB
35x12.50R20 Toyo MT
kennyketten is offline
post #2 of 11 Old 02-02-2014, 01:06 PM
POWERCHOKER
Dantron's Avatar
Yeah. I'm wanting to switch to synthetic as well. What kind are you planning to go with?
Dantron is offline
post #3 of 11 Old 02-02-2014, 01:20 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
No need to do any flush just swap over.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 11 Old 02-02-2014, 01:22 PM
jesilvas's Avatar
No, just drain old, fill with new.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 11 Old 02-02-2014, 02:01 PM Thread Starter
Thinking of going with the Rotella T5 50/50 Blend. I like the thought of the T6 Full Synthetic but they don't offer that in 10W30. I never tow anything except my 19' Bass Boat so I cannot call what I do Heavy Conditions. I have been researching this all day long waiting on the Super Bowl and have found a ton of good information and reason to stay with the 10W30 vs 10W40 or 5W40 ect. I have certainly made my mind up on the 10W30 and I have always heard great things about Rotella so thinking of giving it a shot
KENNY
3.5" Ready Lift
Firestone Air Bags
35x12.50R20 Toyo MT
post #6 of 11 Old 02-02-2014, 02:06 PM
Carli'd6.7's Avatar
Feedback Score: 6 reviews
Run 5/40 Valvoline trublue its full syn and has some wonderful additives in it that aid in the typewriter if you search it in the forum you will see a lot of guys running that oil with great success and a another perk a Ford diesel tech told me these engines love 5/40. So I swapped over and have never looked back.
**14 F-350 CCLB Lariat w/ HIPS !!**Sinister EGR kit** 4 inch Flow-Pro w/ 36" Magnaflow** H&S XRT PRO w/ SPE Heavy Tow Tune**AFE Stage 2**H&S CAC Kit**Edge CTS gauges**ICON stage 3 2.5 w/ tubular radius arms & 4 inch blocks**4.30 Yukons w/ Trutracs**Firestone ride rites**BW turnover**N-Fab cab Lengths**03.5-04 PSD Badges**20" Fuel Maverick Duals**Mag.Hytec Covers**
Carli'd6.7 is offline
post #7 of 11 Old 02-02-2014, 02:16 PM Thread Starter
Thanks Carli for the input,,, guess I just thought my homework was finished...I'm gonna into this. How long have you been running it and how does it react to the Regens? Oh yeah, I think you are Deleted
KENNY
3.5" Ready Lift
Firestone Air Bags
35x12.50R20 Toyo MT
post #8 of 11 Old 02-02-2014, 02:28 PM
POWERCHOKER
Dantron's Avatar
The Valvoline 5/40 sounds better to me. The Rotella seems like something I would put on a sandwich. I'm at 3k miles right now. Should I go ahead and switch to synthetic or maybe wait a while?
Dantron is offline
post #9 of 11 Old 02-02-2014, 03:29 PM
Carli'd6.7's Avatar
Yea I'm deleted but it has all the additives for extended service and fuel breakdown from regening so you're golden .
post #10 of 11 Old 02-02-2014, 03:31 PM
Carli'd6.7's Avatar
The sooner the better you'll notice too that the first time you use it you will get little to no typewriter for the first 800-1000 miles that is found when using almost every other oil out there if not running the XL 90 or whatever that stupid additive is .
