Fuel leak!! - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-31-2014, 06:12 PM Thread Starter
Fuel leak!!
I have a problem and in need of some serious help.. I have a 2011 powerstroke that I changed the fuel filter on the other day and my truck started leaking fuel. I had no idea where it was coming from so I looked into it tonight and now the little line that comes off the inlet to the filter won't seat back and it blows off everytime I turn the key over! Can anyone give me some advice to get it fixed? And also any experience with the leak I'm describing?
2011 F-250 King Ranch-- EGR/DPF deleted, Spartan tuner, Afe intake, leveled
1997stoker is offline
post #2 of 7 Old 01-31-2014, 07:07 PM
Sounds like you might have broken the plastic clip that seats to hold the line on. When you shove the line on you should be able to push the green plastic tab down and hear a slight click.
claws314 is offline
post #3 of 7 Old 01-31-2014, 07:10 PM Thread Starter
Yeah it's the smaller line that comes off the inlet and goes down.. It came loose from that fitting and I can't seem to get it to go back on and stay..
post #4 of 7 Old 01-31-2014, 10:10 PM
Cratos's Avatar
check the o-ring you may have dislodged it
2012 F-250 4X4 FX4, SCLB, 3:55's , Camper & Tow package, air lift bags and pump, Edge insight. Dark Pearl Blue.
Cratos is offline
post #5 of 7 Old 02-01-2014, 06:45 AM Thread Starter
Is the o-ring down in that line? If so how can I get it out? I can't get it to move
post #6 of 7 Old 02-01-2014, 08:14 PM
Cratos's Avatar
ford should have a part # for it or that one to a hydraulic shop and get it in viton
Cratos is offline
post #7 of 7 Old 02-03-2014, 07:18 AM
Cratos's Avatar
yes inside the fitting. a small pick should get it out but be care full not to gouge the plastic.
Cratos is offline
