2011 ford f350 multitude of issues - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 22 Old 01-28-2014, 12:30 PM Thread Starter
Need help with my 2011 ford f350
Tires tearing, extreme wear
Door rattles
Windshield whistle
No help from ford customer service reps.
Hmlustre@aol.com is offline
post #2 of 22 Old 01-28-2014, 01:37 PM
Heavy_GD's Avatar
Quoted: 766 Post(s)
Feedback Score: 3 reviews
what kind of help would you like? What mods do you have, post a pic of the truck.
Tire wear should probably be taken to an alignment shop.
Door rattles, pull the panels and check for loose clips/bolts
Windshield whistle, have a glass shop check it out.
GD - 06 CCSB FX4 Lariat
Originally Posted by G8orFord View Post
My magic wand broke a few years back when my crystal ball fell on it. Ruined the ball too. So we're going to have to figure this one out another way. YOU NEED A MONITOR or at least a good scanner.
Heavy_GD is offline
post #3 of 22 Old 01-28-2014, 01:47 PM
PROUD AMERICAN!!!
Rattlesnake18's Avatar
Quoted: 269 Post(s)
Feedback Score: 6 reviews
I moved this thread to the 6.7 section.
2004 F250 CC Lariat 4x4
Pro Comp leveling kit, 05-07 HD headlights w/ 6k HIDs, Auto Meter gauges, ScanGaugeII, Sinister coolant filter, Blue spring, 6.4 banjo bolts, BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, Straight piped w/ 6" single mitre stack, SCT w/ Hybrid Panty Dropper from Chris @ TSD, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #4 of 22 Old 01-28-2014, 02:00 PM Thread Starter
Thanks for the quick response, I took my truck to my dealership they were unable to repair the above issues.
The trucks thrust and alignment was checked and all was within factory specs, they had had my drivers door apart , they also tried to seal the windshield
I was hoping that Cory or crystal would eventually chime in and give me some direction. So far Erica from customer service hasn't really helped out other than listen to my rant. Lol
post #5 of 22 Old 01-28-2014, 02:04 PM
Heavy_GD's Avatar
Quoted: 766 Post(s)
Listening to you rant is a good first step.
Do you have pics of the tire wear? Is it cupping, the outsides/inside of the tread?
Unfortunately and no disrespect to anyone but I have little faith in most dealers
Heavy_GD is offline
post #6 of 22 Old 01-28-2014, 03:51 PM Thread Starter
I have pictures but don't know how to upload them have to get my daughter to do it.
The rear tires were tearing treads in the center two tread pattern areas and wearing extremely fast I'm on my forth set and its costing me plenty at 377 per tire.
This could be a easy fix for ford just either figure out the cause and fix it or give me another truck
post #7 of 22 Old 01-28-2014, 03:56 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 6 Post(s)
What tires are on the truck? Size and load range
Sounds like one of 2 things. Wrong load range tires or the dealer is overinflating them.
Email: Dave@powerstroke.org
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
http://www.bulletproofdiesel.com/default.asp
http://nolimitfabrication.com/
Dave is offline
post #8 of 22 Old 01-28-2014, 04:18 PM Thread Starter
I had Michelin 275/65 r20 two sets both did the same thing, tire tread tearing off and rapid wear. The third set was bfg all terrain ta 285/65r20 these wore out fast less then one year rear mostly. The four set of tires are toyo 295/65. R20 these tires are wearing out as well
All of these tires are load range e which are what the truck specs call for. As for the inflation
They are set at factory and truck specs its getting costly I have friends who have the same truck and they aren't having a problem. Frd customer serivce says I am overloading the tires. I have a 350 the most I have is 800 pounds of tunge weight
post #9 of 22 Old 01-28-2014, 04:19 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 6 Post(s)
Ford inflation specs or whats printed on the tire.
If its ford spec theyre overinflating the tire by about 20psi and theres your problem. WIth the exception of the BFGs anyway
Edge Insight CTS
Coolant filter
Dave is offline
The Following User Says Thank You to Dave For This Useful Post:
Heavy_GD (01-28-2014)
post #10 of 22 Old 01-28-2014, 04:33 PM Thread Starter
I have to check to see what the inflation is for my toyo tires
I the am I'll check back with you. Thanks for your information
