Water Drainage - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 12 Old 01-25-2014, 02:38 PM Thread Starter
Water Drainage
Drain fuel faithfully every month from the water bowl. Have only owned my truck for 5 months and have 9,000 miles on it. So far I haven't had not one single drop of water come from the filter. I drain it for about 30 sec. and then let it sit in my shop for a week to allow time to settle. I have done this the same way all five times with No Sign of any water. I get my diesel from the same store all the time. My question is,,,, Is this a really good place to purchase diesel "obviously" or is there somewhere else the water can be gathering up that I am not aware of and not checking. Thanks for the input guys... Was trying to wait till the 10,000 mile mark to change fuel filters but might do it a little early out of curiosity...
KENNY
2013 F250 Platinum Tuxedo Black
3.5" Ready Lift
Firestone Air Bags
20x10 BMF Novacane DMB
35x12.50R20 Toyo MT
kennyketten is offline
post #2 of 12 Old 01-25-2014, 02:53 PM
"Stroker 8"'s Avatar
Quoted: 3 Post(s)
Kenny, your in good shape. No water means No contamination. You can change your fuel filter's but I don't think you have anything to be concerned about. As far as an additional place to check for water I can't think of anything else. I have a 32mm socket I keep in my truck in case I think I just got some bad Diesel. Changing your filter's are pretty easy. You can buy filter's online at Dieselfilters.com pretty cheap. It's a good idea to have some spares on hand.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #3 of 12 Old 01-25-2014, 02:57 PM Thread Starter
Thanks Stroker, I'm actually fixing to go to that website you referred me too and order 2 sets so that I have a spare set in the truck. Thanks for the input friend..
KENNY
3.5" Ready Lift
Firestone Air Bags
35x12.50R20 Toyo MT
post #4 of 12 Old 01-25-2014, 02:58 PM
Quoted: 3 Post(s)
No Problem.
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
post #5 of 12 Old 01-25-2014, 03:53 PM Thread Starter
Hey Stroker, I went to the website dieselfilters.com but when I typed in the part # it shows no match for this part #. I guess I'm using the right one. I got it out of my owners book... FD-4615. That is the only Part# I could find for them...
KENNY
3.5" Ready Lift
Firestone Air Bags
35x12.50R20 Toyo MT
post #6 of 12 Old 01-25-2014, 04:25 PM
Quoted: 3 Post(s)
OK, try Dieselfiltersonline.com. Kenny, these are available right now.
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
post #7 of 12 Old 01-25-2014, 04:29 PM Thread Starter
Thanks for the swift reply, will check it out right now...
KENNY
3.5" Ready Lift
Firestone Air Bags
35x12.50R20 Toyo MT
post #8 of 12 Old 01-25-2014, 04:34 PM
Quoted: 3 Post(s)
The prices are pretty competitive and the shipping is fast! Every once in a while there are some good deals on the Bay! There was a deal awhile back on all 4 filter's, fuel, air, oil, and pre-filter for like $95.00 not bad with free shipping. If you come across the oil filter's that have an s after the part number it's the updated filter so no worries.
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
post #9 of 12 Old 01-25-2014, 04:51 PM Thread Starter
Appreciate the info Stroker, just ordered two sets. Checked the Bay before I pulled the trigger and dieselfilters had em beat by $14...lol. Thanks for the help. Really like this forum, handiest thing since the shirt pocket
KENNY
3.5" Ready Lift
Firestone Air Bags
35x12.50R20 Toyo MT
post #10 of 12 Old 01-25-2014, 04:52 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Another simple and easy way to keep the water out of your fuel system is to keep you tank topped off nice and full.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
The Following User Says Thank You to kinnisoj For This Useful Post:
kennyketten (01-25-2014)
