How long is too long to idle for warm up in the morning?? - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 35 Old 01-24-2014, 03:15 PM Thread Starter
Hey guys I have a question...I have a new 2014 F250 and I need to know if letting it warm up 10 to 15 minutes in the morning and before I get off work is too much. I live in Illinois and it's crazy cold this winter. Sucks breaking in a brand new engine in this weather. New to diesels so you input is appreciated. Thanks...
yzf1999 is offline
post #2 of 35 Old 01-24-2014, 03:35 PM
Randy_270's Avatar
Quoted: 2 Post(s)
Its better to drive your truck when its warm than cold. My truck usually warms up for about half hour before I drive in the winter.
2011 F350 Lariat FX4, CCSB, 6.7, 3.55s, 325/65R18 Duratracs, Carli 4.5" Pintop, Flo-Pro, S&B intake, H&S w/ SPE tuning.
2011 Explorer Limited 4WD on 17x7.5s Core Racing Diablo 2s with 245/70R17 Duratracs
Randy_270 is offline
post #3 of 35 Old 01-24-2014, 03:39 PM
Carli'd6.7's Avatar
Feedback Score: 6 reviews
I idle my truck for 10-15 mins every morning and have never had a problem I would just change your oil alittle more frequently than every 7500 like it wants you to a lot of your fuel is getting into your oil while idling cold causing the oil to break down prematurely.
**14 F-350 CCLB Lariat w/ HIPS !!**Sinister EGR kit** 4 inch Flow-Pro w/ 36" Magnaflow** H&S XRT PRO w/ SPE Heavy Tow Tune**AFE Stage 2**H&S CAC Kit**Edge CTS gauges**ICON stage 3 2.5 w/ tubular radius arms & 4 inch blocks**4.30 Yukons w/ Trutracs**Firestone ride rites**BW turnover**N-Fab cab Lengths**03.5-04 PSD Badges**20" Fuel Maverick Duals**Mag.Hytec Covers**
Carli'd6.7 is offline
post #4 of 35 Old 01-24-2014, 06:41 PM
POWERCHOKER
Dantron's Avatar
What is a good oil temp and a good trans temp to reach before driving the truck? Does it matter?
Dantron is offline
post #5 of 35 Old 01-25-2014, 03:41 AM
Randy_270's Avatar
Quoted: 2 Post(s)
In the winter time I try and warm the oil up to at least 100F minimum. The odd time if I'm in a hurry I'll drive at about 90F but I'll drive very easy till it warms up more. For the trams temperature I'm not too worried about that as long as it's not too cold.
post #6 of 35 Old 01-25-2014, 05:18 AM
Quoted: 13 Post(s)
Idling doesn't do much to really warm up the engine. Your oil and coolant will really warm up quicker if you just start driving. The added boost from the turbo pushed the combustion temps up and result in the engine block, oil and coolant coming to temps faster.
I've watched my gauges and done several test.
I can start the truck, let it idle for 1 minute to get the oil circulating and then drive through my residential area at 25 mpg and be MUCH warmer than if I left the truck to idle for 15 minutes.
These engine produce EGTs of around 300° at idle. Just an easy drive to exit the neighborhood produces 450-500° of EGT. By time I reach the freeway on ramp, my coolant temps is already up to 150-160° vs 10 minutes of idling and my temps are only 80°.
The Rapid Heat option produces supplemental heat to the cab when the coolant temps are below 100°. Once your coolant reaches 100° the supplemental heat turns off and the heater core just uses the coolant to supply the heat. The Rapid Heat is a 1500 watt heater coil in the heater assembly. It doesn't produce a lot of heat, but will get the windshield defrosted.
I've even done the Fast idle. Setting the idle up to 1100 rpm for 10 minutes still does not get the engine oil or coolant as warm as 5 minutes of normal driving.
Start your engine, give it a minute to get the oil circulating and then just drive in a normal manner. This will warm your engine up faster and is better for the engine than extended idling.
"Stroker 8" and Arhaifa like this.
2015 F350 CC SRW LWB Lariat, Leveled, BAKflip, Ultra Predator wheels with Toyo A/T 295/65R20, Firestone Airbags and onboard compressor
2011 F350 CC SRW LWB Lariat - Gone
Painted Horse is offline
post #7 of 35 Old 01-25-2014, 05:51 AM
Quoted: 48 Post(s)
It's better to drive your truck warm than cold. Which is why it's best to get it up to operating temp ASAP.
Idling for half an hour to get to 100* EOT is far worse for the engine than getting it there in two minutes of driving
Arhaifa likes this.
drunk on diesel is offline
post #8 of 35 Old 01-25-2014, 06:43 AM
Randy_270's Avatar
Quoted: 2 Post(s)
True but when its -40 outside without wind, even plugged in your oil is going to be really thick so I like to make sure my oil is gonna be warm enough to flow properly.
post #9 of 35 Old 01-25-2014, 07:25 AM
Term3's Avatar
I also use a oil pan heater and even when it's -35C the oil pan is just over +20 degrees
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #10 of 35 Old 01-25-2014, 08:02 AM
Randy_270's Avatar
Quoted: 2 Post(s)
I want one of those . Where did you get it?
