2014 f350 question - Ford Powerstroke Diesel Forum
User Tag List
 2Likes
post #1 of 41 Old 01-23-2014, 04:40 PM Thread Starter
sparky306's Avatar
2014 f350 question
so I just bought a 2014 1 ton. I haven't picked it up yet. I have questions about it since this is my first diesel I own. im not new to diesels, I work as a farmer. but this is my first personal one.
I was thinking about putting a sled deck on it. if I do and load it with 2 sleds or quads will the truck sag?
is there any must do to this trucks?
does a stock f350 look funny with a leveling kit and stock tire? I don't like a truck with rake.
sorry I am sure these questions have been asked before. but thanks for all your comments
sparky306 is offline
post #2 of 41 Old 01-23-2014, 06:28 PM
travisH3's Avatar
Feedback Score: 13 reviews
Truck shouldn't sag with a sled deck on it. And no they don't look bad leveled on stock tires I don't think. In my signature pic my truck is leveled 1.5" up front with stock tires
T-rav
2010 F350 6.4- H&S Single turbo kit, 5" flo pro,No limit SS cold side kit, No Limit intake, MPD billet CCV/oil filler, newton leveling kit, RED Newton traction bars, custom projector retrofit in oem lights and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #3 of 41 Old 01-23-2014, 06:47 PM
If you level it and carry two sleds it will sag quite a bit id bet.
Brett
2013 F250 CCLB FX4 4" PURE PERFORMANCE
2013 F150 FX4 LEVELED 285'S
2001 F350 7.3 CCLB ZF6
rustyshakelford is offline
post #4 of 41 Old 01-24-2014, 01:19 AM Thread Starter
sparky306's Avatar
Whats every ones opinion with air bags in the rear.?
Sent from AutoGuide.com App
post #5 of 41 Old 01-24-2014, 02:40 AM Thread Starter
sparky306's Avatar
Also I was looking at a s&b intake. Would the sock be good for the air filter? I do drive in alot of fields and with my f150 I was finding straw and stuff in my intake.
post #6 of 41 Old 01-24-2014, 03:54 AM
fordtrix's Avatar
I have Ride Rites by Firestone and they are perfect. zero sag towing my 15k lb toy hauler.
2013 F250 Lariat CCSB - Firestone Ride Rite, Bakflip F1, B&W 5th Wheel Hitch, Carli 2.5" with track bar, Fuel Maverick 20x9, Toyo MT 35x12.5, Bushwhacker Extend-A-Fender, Weathertech Mats, Recon 3rd Brake and Mirror Lights, PTM Mirror Caps
2013 Crossroads Elevation 3912 - Loaded
fordtrix is offline
post #7 of 41 Old 01-24-2014, 04:05 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
The only thing Ive noticed with the air bags is a small bouncy feeling when in the very rough stuff. But I imagine I could get some better shock's and cure that.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #8 of 41 Old 01-24-2014, 04:14 AM Thread Starter
sparky306's Avatar
Do you just use a air chuck to fill them or do you have a onboard compressor
post #9 of 41 Old 01-24-2014, 04:36 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
I have just the air chuck and only have to top mine off monthly. The computer would be nice but I don't think its a have to have thing.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #10 of 41 Old 01-24-2014, 05:28 AM
fordtrix's Avatar
What do you keep yours at for psi? I definitely noticed a stiffer ride right after install. Now I keep them at 10psi and barely notice them. The only time I think it may be a little stiff is when hitting sharp bumps, like at bridges occasionally. I have bilstein 5100's and carli add-a-pack in the rear which helps.
I just use the air chuck. right next to my license plate. I only tow a few times a year so it's super easy. Unless someone tows a LOT I wouldn't bother with the compressor and all that. If it's just once a week or a few times a month the chuck is fine (in my opinion)
I can run them at 40 psi (max is 100 psi) and it doesn't sag.
fordtrix is offline
