To Flare or Not to flare? - Ford Powerstroke Diesel Forum
View Poll Results: Put flares on a truck running 13.5" wide tires on stock rims?
Flares 3 23.08%
No Flares 10 76.92%
Voters: 13. You may not vote on this poll
post #1 of 15 Old 01-21-2014, 09:23 AM Thread Starter
Really torn on this one.
F350 running 325/60R20 Duratracs on stock Platinum rims. These are 13.5" tires, and come to about flush with the side of the truck, little further on the fronts.
Really like the look of the truck, but concerned with rock chips (we drive a lot of gravel and a lot of winter), as well as mirrors and windshields of course. I have stock (275/65R20) duratracs on my 05 F350 Harley, and when the truck is clean you notice the rock chips all down the side of the doors and box. Never happened before i put the duratracs on Same goes for the road spray. If driving down a wet road with no-one around I need to run my wipers because of the road spray. Would get flares but... would look ridiculous.
Flares would be Bushwackers, but non-rivot style, the smallest we could get. Just wondering if this is going to look ridiculous with the tires being on stock rims, with flares sticking way too far out.
Neighbor has flares on his Dodge, stock tires, and looks silly from the front and back. Doesn't seem to keep his truck clean either.
Guy at work has a 6.7Ford with flares and stock tires (275/65/20) and it looks really silly. Like he's running his spare tires all round.
What say you?
Thanks,
-Josh
Current Fords:
1978 F150 XLT RCSB
2000 F150 Lariat ECSB (5.4)
2004 F150 Lariat CCSB (5.4)
2005 F350 Harley CCSB (6.0)
2006 F250 XL CCLB (5.4)
2014 F350 Platinum CCSB (6.7)
JoshA is offline
post #2 of 15 Old 01-21-2014, 10:48 AM
fordtrix's Avatar
I've been really torn on this as well. I want/need them but really reluctant based on the looks.
What diameter are your tires? Do you have a lift on your truck?
My tires stick out a good inch and a half past, and after the first week having them, I noticed several rock chips that weren't there previously on my otherwise near mint truck. I saw a lifted truck similar to mine with 37's and it looked great with rivot style flares, just unsure how they would look on my smaller 35's..
2013 F250 Lariat CCSB - Firestone Ride Rite, Bakflip F1, B&W 5th Wheel Hitch, Carli 2.5" with track bar, Fuel Maverick 20x9, Toyo MT 35x12.5, Bushwhacker Extend-A-Fender, Weathertech Mats, Recon 3rd Brake and Mirror Lights, PTM Mirror Caps
2013 Crossroads Elevation 3912 - Loaded
fordtrix is offline
post #3 of 15 Old 01-21-2014, 11:07 AM
PSDJohn's Avatar
flares look great on lifted trucks, but stock or even leveled trucks sometimes look ridiculous with them.
2011 F250 XLT SCLB FX4 35k miles
H&S XRT Pro, Diamond Eye 4in straight pipe, 6in MBRP tip, S&B CAI, Edge Insight CTS, H&S egt kit.
Readylift stage 3 2.5in, 20x10 -24 Fuel Hostages, 35/12.50r20 Toyo MTs, Recon Cabs and Mirror lights.
Back Rack, TSC toolbox, Realtree seat covers.
PSDJohn is offline
post #4 of 15 Old 01-21-2014, 11:15 AM
Quoted: 6 Post(s)
I am running the exact same set up as you and my vote goes against the flares. IMO the truck looks just right with those tires as they are pretty much flush with the side of the truck like you said.
14PlatinumBlack is offline
post #5 of 15 Old 01-21-2014, 11:35 AM
GregsSD's Avatar
Garage
I agree that running stock rims will not look good with flares, unless you are just running the factory flares that are more like a trim piece.
I love having flares on my truck, but I am running 10" wide wheels with quite a bit of offset and 13.5" wide tires.
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #6 of 15 Old 01-21-2014, 11:36 AM
POWERCHOKER
Dantron's Avatar
I actually have some Bushwacker Extend-A-Fender flares being painted at the moment. However, I have a 6 inch lift and 37x13.5x20 tires on 20x10 wheels. My tires stick out about 2 inches from the wheel wells. I think the wheels look fine as is, but I'm wanting to install the flares to add protection and some more body to the truck. I believe the "pocket style" flares extend outward 2 inches and the "extend-a-fender" flares extend outward 1.75 inches. If you're getting the smaller "OEM" style flares, the width will be even less. You can look at some two-tone painted factory Super Duty's with OEM flares already installed to get a better idea of what that will look like. The only truck I've seen that looked silly driving down the road was a stock F-150 with the "pocket style" fender flares. Here is an advertised picture of an F-250 with "extend-a-fender" flares on rather narrow wheels, but the angle is hard to determine if they look good straight on..
http://www.fordtruckclub.net/forum/p...per_duty_2.jpg
Dantron is offline
post #7 of 15 Old 01-21-2014, 03:33 PM
IMO, I don't like the look on these newer model trucks, they look good on the older model trucks. Now in Dantron's case I would probably get them with the set up he has. And it would still be a hard decision. They seem to scratch up easily and the two on the rear catch all the abuse with you and others leaning over to get things out of the back of the truck. I had a set on my other truck and will never have them again because of that. I had then 4 months and they looked 5 years old. They seem to catch all the scratches. My 2 cents....
KENNY
2013 F250 Platinum Tuxedo Black
3.5" Ready Lift
Firestone Air Bags
20x10 BMF Novacane DMB
35x12.50R20 Toyo MT
kennyketten is offline
post #8 of 15 Old 01-21-2014, 03:35 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 230 Post(s)
In my opinion there is nothing worse looking than a truck with flares that stick out past the wheels. I would get you a set of street or oem flares if anything.
Keith
2014 Platipus
AP Intake
Mini Maxx w/ Tyrant MCC Tunes
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #9 of 15 Old 01-21-2014, 03:40 PM
montana6.0's Avatar
There a huge help for me blocking rock chips on my rockers. I Drove gravel roads a lot in ND. But make sure you put some clear 3m tape or whatever where the trim piece goes against your paint otherwise rubs the paint right off frustrating.
2010 F350 auto
2inch leveling kit
35'' toyo m/ts
20'' montsers
dpf cat delete
h&s mini Max
s&b cai
montana6.0 is offline
post #10 of 15 Old 01-21-2014, 04:07 PM
I have the flares on mine and like them… now I just bought new wheels and tires because the old set up that came on the truck, the wheels and tires did not stick out further than the flares. now that I have 20x12" rims and 37s, the stance looks great! if going with flares, tires have to stick out further than the flares to look good. if not, the tires look to small for the truck
2012 f250 6.7
6" rough country lift
37" trail grapplers
20x12 fuel hostage
awg8 is offline
