What do you drain the fuel filter into? - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 21 Old 01-12-2014, 04:56 PM Thread Starter
I'm just curious on how everyone is doing this? The fuel filter under the truck is supposed to be drained approximately once a month or so.. what does everyone do with the fuel?
Stock for now.
Bluwaterbrew84 is offline
post #2 of 21 Old 01-12-2014, 05:05 PM
fordtrix's Avatar
Also, do you fully drain then cycle the key per the manual when changing fuel filters? I see many say they just drain the water but it doesnt seem like "just water"
Sorry bout the thread jack, but somewhat relative
2013 F250 Lariat CCSB - Firestone Ride Rite, Bakflip F1, B&W 5th Wheel Hitch, Carli 2.5" with track bar, Fuel Maverick 20x9, Toyo MT 35x12.5, Bushwhacker Extend-A-Fender, Weathertech Mats, Recon 3rd Brake and Mirror Lights, PTM Mirror Caps
2013 Crossroads Elevation 3912 - Loaded
fordtrix is offline
post #3 of 21 Old 01-12-2014, 05:43 PM
I never do it, I just change filters regularly.
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
post #4 of 21 Old 01-13-2014, 06:19 AM
"Stroker 8"'s Avatar
Quoted: 3 Post(s)
I let mine drain for about 25 seconds. Then I let it sit for about a week. If it looks ok after a week I put it back into my tank. I've never had water issues or anything else. It makes a difference where you purchase your fuel from. I don't know how many times I have passed gas stations when they looked sketchy to me and just kept going until I found one that looked ok.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #5 of 21 Old 01-13-2014, 07:03 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
If it dosnt look bad I dump it in my tractor. If it looks bad I pour it on the boards on my trailer.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #6 of 21 Old 01-13-2014, 07:43 AM
When I loosened mine for the first time the fuel leaked around the valve and not out the spout. Doesn't seem right but it was the first time
Brett
2013 F250 CCLB FX4 4" PURE PERFORMANCE
2013 F150 FX4 LEVELED 285'S
2001 F350 7.3 CCLB ZF6
rustyshakelford is offline
post #7 of 21 Old 01-13-2014, 06:47 PM
350ninty7's Avatar
Drain mine the first week of each month regardless of how many fill ups. I use a clear 1QT Mason Jar and drain about a pint into it. Due for first Fuel Filter change by Ford at 15,000 this month. Save all fuel receipts and buy my fuel from 2 high volume stations.
2012 F350 XLT 6.7 CC LWB SRW
11,500 GVW FX4 Off Road, Camper, & Prem XLT Options
2012 Montana Mountaineer 326 5th Wheel
SOLD and Missed
1997 F350 XLT 7.3 Liter Power Stroke
Reg Cab 4X4 Off Road Pkge
5 spd Manual with South Bend Clutch Upgrade
AFE Stage 2
Diamond Eye 3" Down Pipe 4" Exhaust Cat Delete
TW Tunes
WARN Winch
Original Owner 179,000 Miles
350ninty7 is offline
post #8 of 21 Old 01-13-2014, 07:10 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Im not sure about the 6.7's but for the 6.0's they make a handy little screw/plug type if thing that you can loosen and tighten with just your finger. It makes the whole job a lot simpler.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #9 of 21 Old 01-13-2014, 07:24 PM
wvrrcarknocker's Avatar
Feedback Score: 3 reviews
Send a message via Yahoo to wvrrcarknocker
Yes they do, and this guy just ordered one! 6E7Z-9C082-A is the part number.
Originally Posted by ChiefRocka View Post
Great truck, but ugly and I felt like I was driving a penis down the road .....
wvrrcarknocker is offline
post #10 of 21 Old 01-13-2014, 08:52 PM
Brett
Likely opened it too far. The valve will leak if you open it more than few turns. Just open it enough to get it flowing, then stop turning.
I have been a little lazy draining mine since the weather turned nasty and the asphalt is constantly wet and/or salty and too nasty to lay on. LOL. I check it about monthly or so, and if I don't see any water in the bottom of my catch cup, I pour 90% off the top back into the tank and toss the 10% remainder just in case.
Greg
hammong is offline
