Horrible mileage lately - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 9 Old 01-09-2014, 06:33 PM Thread Starter
TXGold's Avatar
I recently changed oil to same the truck had, Amsoil synthetic, cleaned air filter and fuel filters, and added coolant additive. I have since then gotten horrible mileage. I used to be able to get a 17-18MPG on the liar meter pretty easily and every now and then I'd get a 19-20MPG. I can't get over 15 doing the same type of speeds, and if anything less as for some reason I have been driving more conservatively lately. Could it be the cold weather or the servicing? Makes no sense.
I have the .34 software on the mini max and nothing has changed. I did notice before or maybe towards the beginning of this bad mileage issue that my truck would seem like it wasn't getting much power and I would look and there would be zero boost reading on the mini max. I would then hit down a level and back up to the high that I leave it on and it would then start making boost.
Please help as this is pissing me off cause I am almost at 36,000 miles and end of warranty.
2014 Ram 2500 MC Limited Black/Black, 295/65R20 Toyo AT2Ext's, Thuren 2.5 Springs, Fox/Thuren 2.0 ITP Shocks
TXGold is offline
post #2 of 9 Old 01-09-2014, 06:52 PM
Depending on where you live it's the winter fuel blend.
Tjmaxx is offline
post #3 of 9 Old 01-09-2014, 09:11 PM
Almost sounds like you have a boost leak somewhere, which will definitely cost you power and mileage.
Winter fuel blends will cost you a solid 1.5-2 MPG as well. Let us not forget that a cold engine is less efficient than one operating at optimal temperatures. It's all working against you in the middle of winter.
Greg
hammong is offline
post #4 of 9 Old 01-10-2014, 07:46 PM Thread Starter
TXGold's Avatar
Houston, TX. Hasn't been that cold. I also make 25psi when I'm on it and no noticeable power loss, but I haven't checked for these reasons. I guess I need to check the hoses. Totally po'ing me, and I shouldn't let it, but I can't help thinking somethings wrong. Got 13 MPG today not goosing it at all but doing 80MPH on GPS, totally flat terrain. Do you think we would have a winter blend down here? I've known about that blend but didn't think it would be this big a problem. If I went 55MPH it wouldn't be 16MPG.
TXGold is offline
post #5 of 9 Old 01-11-2014, 05:00 AM
Hawkeye Diesel's Avatar
I'm pretty sure you guys down in Texas get winter blend diesel. I know here in Iowa, starting around Nov 1st and lasting until mid April, my mileage drops from 19 mpg avg to 14-15 mpg avg.
[/SIGPIC]2008 F250 Lariat, 8" lift 37x12.5 20 Nittos, Spartan tuned running 275 with an AFE stage 2 and 4" straight pipe. Next up, full EGR and Cooler delete
Proud to be a Union Steamfitter
Hawkeye Diesel is offline
post #6 of 9 Old 01-11-2014, 05:30 AM
I can't comment on wether or not you get winter blend fuel but I will say 80 mph will hurt your mpg for sure. With these trucks the sweet spot is 60-65 for mpg.
Tjmaxx is offline
post #7 of 9 Old 01-11-2014, 03:00 PM
PSDJohn's Avatar
80mph usually kills my mileage. Winter fuel plus 80mph you would see a significant drop.
2011 F250 XLT SCLB FX4 35k miles
H&S XRT Pro, Diamond Eye 4in straight pipe, 6in MBRP tip, S&B CAI, Edge Insight CTS, H&S egt kit.
Readylift stage 3 2.5in, 20x10 -24 Fuel Hostages, 35/12.50r20 Toyo MTs, Recon Cabs and Mirror lights.
Back Rack, TSC toolbox, Realtree seat covers.
PSDJohn is offline
post #8 of 9 Old 01-11-2014, 04:01 PM
mcd
Most likely winter fuel. My truck is all stock, and I have seen mpg drops both this winter and last winter. Usually gets better around feb/march, when fuel blends change.
mcd is offline
post #9 of 9 Old 01-11-2014, 09:34 PM Thread Starter
TXGold's Avatar
Sounds like they should lower the price since the fuel doesn't have same amount of energy, all so it won't freeze, I'm guessing??
TXGold is offline
