When do you plug in? - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 28 Old 01-07-2014, 08:28 AM Thread Starter
factoryflood's Avatar
I was in Vermont the past week with temps as low as -35 windchill. Went to start my truck and she wouldn't fire. Had to have a buddy tow me to a power outlet and plug in overnight to get her to crank.
At what temp do you plug in?
How long do you leave her plugged in for? Overnight? On a timer for a certain amount of hours?
2012 F350SRW CCSB
H&S Mini Maxx with MCC, Spartan with war hammer(FOR SALE), 5" down pipe back exhaust, AFE Stg 2 Cold Air Intake, 6k 55w HIDS, Eagle Alloys 014 20x9 0 offset wheels, 35x12.50R20 Toyo Open Country AT2 Xtreme, UWS toolbox
Inside- Pioneer AVH3200BT, 2 Kicker CVT 12's, Kicker ZX1000, 4 gague wiring, Custom sub box, 20% tint all the way around
factoryflood is offline
post #2 of 28 Old 01-07-2014, 10:05 AM
I've never had any trouble with my '12 starting in the cold weather. The lowest it has seen is in the single digits but I've read on this forum of other guys starting in the negatives with no issues. Might need to have yours checked out.
When I do plug it in, I have it set on a timer for approx. 3 hrs before I will start and us it.
2012 F-350 Crew Cab Lariat 4X4
H&S XRT Pro; DPF deleted; S&B Air Intake
2006 F-350 Crew Cab XLT 4X4 *SOLD*
hmdavid is offline
post #3 of 28 Old 01-07-2014, 10:23 AM
Tweez's Avatar
Quoted: 4 Post(s)
I don't even have a block heater, and in Michigan right now we are in a deep freeze, has started better than my wife's and her car is in the garage. Did you gel up?
Tweez is offline
post #4 of 28 Old 01-07-2014, 10:29 AM
Godo question Tweez.
factoryflood, are you using an additive to prevent gelling? If not, that could have caused the "no start" issue.
hmdavid is offline
post #5 of 28 Old 01-07-2014, 01:53 PM
mach14604's Avatar
Mine has been plugged in since late Sunday night. It is in a garage and has anti-gel from Ford in it AND a full tank of fuel. I have been as low as -40 the last couple of nights. But have been off work since then and have not started it up. I think I will tomorrow or tonight maybe?
Want to Buy Ford Racing M-55 Exhaust
mach14604 is offline
post #6 of 28 Old 01-07-2014, 02:28 PM Thread Starter
There was no additive in it. I put stynadine or however it is spelled into the tank at the same time I plugged it in. Do you guys think the gelling could be the issue?
Sent from AutoGuide.com App
2012 F350SRW CCSB
post #7 of 28 Old 01-07-2014, 03:09 PM
PSDJohn's Avatar
I usually dont plug mine in but i think im going to start. Started mine for the first time in 2 1/2 days unplugged and boy she was cranky. It was like 1 degree with -22 windchill when i started it. She started fine but after it fired it ran kinda rough and smoked like ive never seen before.
2011 F250 XLT SCLB FX4 35k miles
H&S XRT Pro, Diamond Eye 4in straight pipe, 6in MBRP tip, S&B CAI, Edge Insight CTS, H&S egt kit.
Readylift stage 3 2.5in, 20x10 -24 Fuel Hostages, 35/12.50r20 Toyo MTs, Recon Cabs and Mirror lights.
Back Rack, TSC toolbox, Realtree seat covers.
PSDJohn is offline
post #8 of 28 Old 01-07-2014, 03:18 PM
deejay's Avatar
I normally plug in at -20c (-5f) or below but have had started without plugging in temps between -25 and -30 temperature without factoring windchill. Never had any issues with fuel gelling and we see temps in the -40 to -45 range for short periods pretty much every winter.
2012 F350 Lariat FX4 CC LB
Pace Edwards JackRabbit Cover
deejay is offline
post #9 of 28 Old 01-07-2014, 03:26 PM
luke7.3's Avatar
Quoted: 24 Post(s)
Gelling is definitely the issue! Keep over 1/2 tank fuel at all times in the cold winter months. Use diesel kleene in the white bottle with the cetane boost. Don't buy the little bottles, get the gallon bottle which is way more bang for your buck. My 6.4 doesn't even have a block heater (which is bull. IDK when Ford/international stopped that deal because I thought all diesels came standard with one) and it starts just fine, even this morning with -40 windchills
Luke
97 F250 CCSB 4 inch straight pipe, 6637 intake, TS 6 pos (daily)
08 F350 6.4 Reg Cab flatbed Spartan tuned, AFE Intake, DPF/DOC Delete(work truck)
luke7.3 is offline
post #10 of 28 Old 01-07-2014, 03:40 PM
Fuel gel has nothing to do with plugging block heater in. I plug my 6.4 in almost all winter and ended up with gelled fuel today ......even though I use diesel kleen artic every tank! It was well below zero degrees here in missouri last few days and truck parked outside. I changed fuel filters and will also start using Howes anti gel cetane boost from now on.
Plugging in your truck does help make starting easier by keeping the block warmer. I use 5w40 oil and that helps too. I believe it is recommended to plug in when temps are 20 f or lower. I do it all winter and set a timer to come on 3 hrs before I leave for work. This is all thats needed. The heater is high draw on power and you electric bill will reflect leaving it on all night.
2010 F350 Lariat, Ready Lift 2.5" level kit, Toyo Open Country AT2-35 x 12.5 R20 on Worx Tyrant rims
sugelle is offline
