DEF question - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 4 Old 01-01-2014, 06:53 AM Thread Starter
kdskidoo's Avatar
DEF question
I read in the manual that the def fluid freezes around 12 F. was wondering if there is something I need to do to prevent this when using the truck in those temps. thanks in advance.
2007 F 250 superduty Highline Pkg.
10" lift-Rock Krawler coil over 4 link pre-runner system w/ Fox res. shocks all around
dual BDS steering stabs
custom trac bars w/polished stainless inlay w/"FORD" lazer cut in center and flames on ends
Raptor coating on frame axles, etc.
bushwacker pocket style fender flares
Jesse James Lawless 18 X 10 chrome wheels
38.5 X 14.5 Pro Comp Xtreme mud tires
AMI Billet door handles and fuel door
4" turbo back stainless exhaust w/ 5" tips
much more to come
kdskidoo is offline
post #2 of 4 Old 01-01-2014, 07:13 AM
daystrom's Avatar
From what I understand, the DEF tank has a small heater in it. The truck doesn't start using DEF until a few miles have passed which would allow time for it to defrost from the heater.
Also when you shut the engine off, you can hear a pump running for about 30 seconds. This is a purge pump that purges DEF from the lines so it doesn't freeze up in the lines.
2012 F-350 Lariat 4x4 6.7 PSD
Platinum metallic / adobe accent
"Your worthy Sir Topham Hatt thinks I need to learn. He is mistaken. We Diesels don't need to learn, we know everything. We come to a yard and improve it. We are revolutionary!"
daystrom is offline
The Following User Says Thank You to daystrom For This Useful Post:
kdskidoo (01-01-2014)
post #3 of 4 Old 01-01-2014, 07:18 AM Thread Starter
kdskidoo's Avatar
thanks, wow there sure is a lot more things on these new trucks that can go wrong compared to my '97 7.3.
much more to come
kdskidoo is offline
post #4 of 4 Old 01-01-2014, 08:56 PM
Hoverp's Avatar
Thanks for they, I love learning about this truck, and I wondered how they did that, although I've never heard the pump run post shutdown.
Does it sense the OAT and only pump it back to the tank if it is below 12 degrees? That wouldn't work when the temp drops a bunch during the night.
2014 F350 CC Short bed, Fully loaded, Platinum Edition. 6.7L Scorpion Tuxedo Black. 3.55 ELD, FX4, Sup heater, 5th package , BFG Radial All Terrain: icon_ford:
Hoverp is offline
