oil change. - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 13 Old 12-23-2013, 07:36 AM Thread Starter
Tweez's Avatar
Quoted: 4 Post(s)
oil change.
I just changed my oil on my truck, I have one question, does the 13.1 qts include the one that I put in the filter, if so that means I only need to put in just 12 qts right, this might sound stupid but I was just wondering. Thanks
Tweez is offline
post #2 of 13 Old 12-23-2013, 09:42 AM
"Stroker 8"'s Avatar
Quoted: 3 Post(s)
Not stupid at all. You are correct, 13 quarts total. There's a neat little valve you can buy that screws into your drain plug so when you change the oil it won't come out all over you. Someone who has one might chime in for further details.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #3 of 13 Old 12-23-2013, 09:49 AM Thread Starter
Tweez's Avatar
Quoted: 4 Post(s)
The drain plug wasn't to bad but the filter was a pain, I always do my own oil changes but never had to fill the filter first. Thanks for the help Stroker 8
Tweez is offline
post #4 of 13 Old 12-24-2013, 03:25 AM
kdskidoo's Avatar
I just bought a used 2011 and the dealer changed the oil before I bought it. I haven't looked at the directions in the book for changing the oil yet, but by what I'm reading hear they want you to fill the new filter with oil before installing it on the truck. I have 2 questions, why and is this really necessary?
2007 F 250 superduty Highline Pkg.
10" lift-Rock Krawler coil over 4 link pre-runner system w/ Fox res. shocks all around
dual BDS steering stabs
custom trac bars w/polished stainless inlay w/"FORD" lazer cut in center and flames on ends
Raptor coating on frame axles, etc.
bushwacker pocket style fender flares
Jesse James Lawless 18 X 10 chrome wheels
38.5 X 14.5 Pro Comp Xtreme mud tires
AMI Billet door handles and fuel door
4" turbo back stainless exhaust w/ 5" tips
much more to come
kdskidoo is offline
post #5 of 13 Old 12-24-2013, 03:29 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Ive always done this and was taught as a little kid to fill the filters before installation. Ive always assumed it was to help the system build pressure faster and to get oil up into the motor instead of having to take the time to fill the filter first.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #6 of 13 Old 12-24-2013, 03:41 AM
kdskidoo's Avatar
does make sense, but I've never done it with any of my equipment. I thought maybe this was something specific for the 6.7
much more to come
kdskidoo is offline
post #7 of 13 Old 12-24-2013, 03:43 AM
texaslimeaide's Avatar
Same here. Any filter you can fill before installing helps the oil system react faster after a full drain.
2013 6.7 Powerstroke F250 XLT Crew Cab 4X4 First Owner. Amsoil OE 15W40 Diesel Motor Oil. MB Wheels and Cooper 34.5" x 12" tires.
SOLD!! 2006 F250 Lariat Crew Cab 4x2 88k miles, 4" Diamond Eye Turbo Back Exhaust, Amsoil 15W40 Synthetic Heavy Duty Diesel and Marine Motor Oil, Ea Amsoil 15k oil filter, Oil Charge Systems Amsoil Bypass Filter, SCT TSX (no custom tunes yet), Sinister Coolant Filter Kit, Zoodad Mod, Custom Diesel EGR Cooler Delete.
texaslimeaide is online now
post #8 of 13 Old 12-24-2013, 04:49 AM Thread Starter
Tweez's Avatar
Quoted: 4 Post(s)
I thought the same thing, I never have filled the filter on any other car or truck that I have changed the oil on.
Tweez is offline
post #9 of 13 Old 12-24-2013, 04:54 AM
Quoted: 3 Post(s)
Unless you already know this, next time you change your own oil, take a center punch to the bottom of the oil filter before removing it. Makes life easier.
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
The Following User Says Thank You to "Stroker 8" For This Useful Post:
kennyketten (12-26-2013)
post #10 of 13 Old 12-24-2013, 05:26 AM Thread Starter
Tweez's Avatar
Quoted: 4 Post(s)
Yepper I did that, but still was one of the messes filter iv ever done, but I love this truck...
Tweez is offline
