250 or 350 SRW for pulling a gooseneck horse trailer? - Ford Powerstroke Diesel Forum
post #1 of 23 Old 12-22-2013, 07:28 AM Thread Starter
I currently drive a 2002 f350 dually with the 7.3. I am pretty certain I am about to trade it in on a new 2013 to take advantage of the 0% financing, but I am having a hard time deciding between the F250 Lariat and the F350 Lariat SRW, both in short bed. My dually is a bit big for daily use, so it was either get another car, or downsize a bit. The new truck will be diesel. I currently have a 3 horse featherlite gooseneck trailer which weighs about 3000 lbs. At max with 3 horses and gear(which is rare), maybe coming in around 7000 lbs. I understand that the only difference between these two models is the badgeing and an extra leafspring in the rear. I may upgrade to a bigger trailer down the road.
So my question is, am I better off with the F250 or F350? The pickings are very slim on Long Island with 2013's in the Lariat trim with the Diesel in a color I can tolerate. We are literally talking 5 250's and only 2 350's, so deciding between the two really narrows down my possible options greatly.
PS, just to head this of at the pass, I am aware of the limitations of a short bed pulling a gooseneck. My featherlite is a 7' wide with a tapered nose, and will not be a problem. I am aware that if I upgrade to a larger trailer, I will lose some maneuverability.
bfuccillo is offline
post #2 of 23 Old 12-22-2013, 07:30 AM
marshal.smith7's Avatar
Id go 250. It will be plenty good enough. With loads that light a 1 ton would be a waste imho
marshal.smith7 is offline
post #3 of 23 Old 12-22-2013, 07:37 AM Thread Starter
Even if they are virtually identically priced? I think the 350 may be $100 more than the 250. The decision between which one determines which dealership I go to and what colors are available to me, thats the main reason why figuring this out is so important. I have pretty much narrowed my options down to 1 350 at one dealership, or between 2 250's at two different dealerships.
What about resale value, would one be more valuable than the other down the road?
post #4 of 23 Old 12-22-2013, 07:44 AM
Now that you mention the price difference.. 350. One can infer a 350 would bring more resale but I cannot tell you for sure. Let's put it this way. The 250 is plenty enough truck for what you need, but with a 350 beingso cheap it might be wise to go that route just to possibly get more resale.
post #5 of 23 Old 12-22-2013, 09:19 AM
I'd go 350 for the price especially if you may get a larger trailer in the future.
Tjmaxx is offline
post #6 of 23 Old 12-22-2013, 10:15 AM
F350SD's Avatar
rather have it and not need it than need it and not have it
2015 F450 Platinum (me happy)
Montana 3625RE 5th wheel (wife happy)
USMC 89-93 / Wounded Warrior Project supporter
F350SD is offline
post #7 of 23 Old 12-22-2013, 10:37 AM
alaskan155's Avatar
Quoted: 50 Post(s)
350 srw and f250 srw are basically the same truck, same frame, the f250 can be optioned with f350 springs
i believe the f350 has a higher gcwr and gvwr to legally tow heavier loads is the major difference and some states cost more to register.
2002 F250 7.3/JW Tow master 4r100 203k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range , 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #8 of 23 Old 12-22-2013, 10:59 AM
Fire From the Clouds!
Horizon122's Avatar
Quoted: 90 Post(s)
I'd go with the F350 because even though you'll have the extra support it's better to have it and not need it then to not have it and need it.
Also I agree NY is horrible for buying these trucks and I had to go to Jersey to get mine. I suggest doing the build it now thing on Ford's website and pick what you want and have Ford either build it for you or pick from related ones. I did the build it now myself as I was bored and only found about 4 F350's where 1 or 2 were Lariats within 10 dealerships. The rest were F250's and mostly XLT's.
2002 Ford F350-Lariat-CrewCab-LongBed-7.3L PowerStroke Intercooled Turbo Diesel!
2.5 Pro Comp lift on 315/75r16 Fierce M/T's
Enough Stuff To Pull Yours!
Horizon122 is offline
post #9 of 23 Old 12-22-2013, 11:12 AM
ucpa111's Avatar
Quoted: 2 Post(s)
I'd go with the F350. I don't "need" the F350 I have...but when I want to legally tow at the max or load payload to max - I can. And, the payload is a fair difference.
2012 F350 CCLB 3.55 ELD with 20s. Lariat package, Chrome, FX4, Clearance Lights, Rapid Heat, Two Tone, Upfitters, HD Alternator, 5th Wheel prep, Truxedo Lo Pro Tonneau. Linex. On board air and shocker XL train horns.
THIS THING ROCKS!
ucpa111 is offline
post #10 of 23 Old 12-22-2013, 11:25 AM
"Stroker 8"'s Avatar
Quoted: 3 Post(s)
F-250 just because I have one! Someone had to stick up for the 3/4 ton's haha. If your never going to pull more than you plan to, why overkill it and pay more at registration time? Just my opinion. Good luck and keep us posted.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
