Low fuel - noisy fuel pump - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-26-2013, 11:08 AM Thread Starter
daystrom's Avatar
Quoted: 2 Post(s)
When my fuel is low, I've noticed the fuel pump whines, sometimes pretty loud. While filling the tank up, the whine progressively gets quieter as the fuel level increases.
I can't pinpoint where the whine is coming from, almost sounds like from under the hood.
Has anyone has this happen?
2012 F-350 Lariat 4x4 6.7 PSD
Platinum metallic / adobe accent
"Sir Topham Hatt thinks I need to learn. He is mistaken. We Diesels don't need to learn, we know everything. We come to a yard and improve it. We are revolutionary!"
daystrom is offline
post #2 of 5 Old 10-26-2013, 11:16 AM
99PSD-White's Avatar
I think there is a SSM on this and its normal operation.
2013 F250 Lariat 4x4 Loaded. H&S mini maxx, 5" exhaust, S&B intake, and EGR delete, AMP steps, tonneau cover
2011 F150 Ecoboost FX4 Screw. All stock except for a livernois Tuner. SOLD!
Early 99 CCLB Pro comp 6.5" lift w 18" hulk wheels wrapped in 37" KM2s, Amp steps, Straight pipe, AIS intake, Dp Tuner, isspro gauges (boost,trans,pyro), 05 front clip, traction bars, 6.0L trans cooler, built trans.SOLD!!
99PSD-White is offline
post #3 of 5 Old 10-26-2013, 05:30 PM
Quoted: 2 Post(s)
Can you post a copy of the SSM?
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
post #4 of 5 Old 10-26-2013, 06:58 PM
thirdgenlxi's Avatar
When the fuel level is low and the fuel sloshes around in the tank, it starts to suck up air into the lines. What you hear is actually the lines vibrating.... if you grab the lines on the secondary fuel filter (the one on the engine) while it's doing it you'll be able to feel them vibrating really fast, causing the buzzing sound you hear. Usually cycling the key off and back on takes care of it
Here's the SSM....
"44238 2011-2014 - F-Super Duty - 6.7L - Diesel Fuel Conditioning Module (DFCM) Vibration/Buzzing/Growl
Some 2011-2014 F-Super Duty vehicles equipped with a 6.7L diesel engine may exhibit a vibration/buzz/growl noise from the DFCM and/or low pressure fuel lines. If the noise is experienced when the fuel level is at or below 1/4 tank, this is a normal characteristic and is due to slight amounts of air entering the fuel system during low fuel level conditions. No repairs should be attempted. Fuel system and vehicle durability as well as vehicle drivability and distance to empty (DTE) are not affected. If the noise is occurring with the fuel level above 1/4 tank, follow Pin Point Test MA in the on-line PC/ED to diagnose the low pressure fuel system. The DFCM should not be replaced for audible noises until the fuel filters have been replaced and the system reevaluated.
EFFECTIVE DATE: 16-OCTOBER-2013"
-Jared
Alloy Grey '07 Edge SEL - 114k miles, the young pup
Black '89 Accord LX-i - 437k and still kicking
Black/Red '04 CBR 600 F4i - 267k going strong
facebook.com/thirdgenlxi
thirdgenlxi is offline
post #5 of 5 Old 10-27-2013, 05:03 AM Thread Starter
daystrom's Avatar
Quoted: 2 Post(s)
Thank you Jared for posting this!
Good to see it is normal. I wonder why you don't get noise like this on other types of vehicles?
daystrom is offline
