Cold weather package? - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 13 Old 10-23-2013, 02:47 PM Thread Starter
Northernford's Avatar
Hi all,
I have a 2011 f350 with a plug behind the front license plate that the dealer told me is the plug in for the cold weather package. Since I don't use it as a daily driver and when I don't drive it, the truck is under the front of my camper, should I have it plugged in? Especially since it is starting to get colder? Truck can sit up to 3 weeks without being started, usually less though.
2011 F-350 FX4
Northernford is offline
post #2 of 13 Old 10-23-2013, 03:35 PM
I'd have it on a battery tender for both batteries if it sits that long. You can plug in the block heater for a few hours before you're ready to drive it during cold weather. Amazing how great that works! No need (harm?) plugging the block heater in for 3 weeks.
BlueF350 is offline
post #3 of 13 Old 10-23-2013, 03:52 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
You could also look into a good solar panel set up as well to keep those batt's at 100%. I would be concerned about the mice if my truck was parked that long.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 13 Old 10-23-2013, 05:19 PM Thread Starter
I have power outlets where I keep the camper, so I keep the camper plugged in the whole time but am wondering if I should plug the trucks block heater in. Any harm in doing it and leaving it for 3 weeks at a time?
2011 F-350 FX4
post #5 of 13 Old 10-23-2013, 05:30 PM
brendan.9's Avatar
pointless leaving it plugged it in for that long as stated above only needs to be plugged in 3hrs or so before starting its more of a block heater i believe so not gonna do any good would have a batter tender on it tho so the battery don't die.
2013 F350 5" straight exhaust, Mini Maxx, CAI, H&S egr delete
03 SVT Cobra Whippled 632 rwhp 572rwtq Torch red 10th Anniversary coupe.
brendan.9 is offline
post #6 of 13 Old 10-23-2013, 05:42 PM
You could leave it plugged in that long if your just itching to double your utility bill. Personally I wouldn't bother plugging it in unless your like 0 degrees. Even my old 08 I never once plugged it in. These trucks don't need it like the old 7.3s did unless your in climate way below freezing
superdave99gt is offline
post #7 of 13 Old 10-23-2013, 08:36 PM
I'd be worried about burning out the block heater by running 24/7 unnecessarily. D
Don't forget the power cost either, the block heater is between 700 and 1000 watts.
Plug it in when you need it, overnight is OK but 3-4 hours is all that's necessary.
Greg
hammong is offline
post #8 of 13 Old 10-23-2013, 08:39 PM
RollinEarly99's Avatar
Quoted: 6 Post(s)
Feedback Score: 10 reviews
Agreed! Only plug it in 3 hrs (or night before) before you plan on driving the truck... Otherwise your just paying higher electric bills to maintain the same level of heat achieved after the first 3hrs of being plugged in.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #9 of 13 Old 10-23-2013, 08:49 PM
Yeah it's a Turbo Diesel
mts678's Avatar
Feedback Score: 12 reviews
Get a timer, then you don't have to leave it plugged in overnight or wake up 3 hours before you normally do to plug it in
Sent from AutoGuide.com App
Marshall
2000 F250 7.3L CCSB 2WD
Tinted | Focal speakers & 12" Kicker | CTS Edge Insight | Wicked Wheel | 6 pos chip | 05 grill & lights | 08 mirrors & tailgate | EBVP delete | 08 console | Nathan P3 train horns & Onboard Air
Switching to hid's? Do it right!
mts678 is offline
post #10 of 13 Old 10-23-2013, 08:54 PM
Quoted: 6 Post(s)
That's what I did when I had my last 7.3... Walmart sells a digital timer for like $8.99 and it worked like a charm. If you leave for work a 6:30 set the timer to power on by 3:30-4:00 and have it turn off at 7:00 just incase you don't drive the truck for some reason that day.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
