When to rotate tires? - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 6 Old 10-19-2013, 11:31 AM Thread Starter
TX_TRU_STUD's Avatar
Quoted: 31 Post(s)
Anyone know what the interval is? I looked in all the manuals and online and found nothing definitive.
I found that Gassers should do it at 7500 miles. I used to do my old truck at 5K which was every oil changed. I planned on rotating my tires at every oil change but this truck could go 10K miles before needing a change.
Any help would be great. I am not looking for "I do mine at X amount". I am just looking for what Ford states in it's manuals, etc.
TX_TRU_STUD is offline
post #2 of 6 Old 10-19-2013, 11:39 AM
I_AM_RP3's Avatar
Its 7500. The same as the gassers. When the diesel supplement does specify a different interval, or one at all, you refer to the main manual which is the same as the gasser. Hope this helps.
Rob
Sent from my DROID RAZR
I_AM_RP3 is offline
post #3 of 6 Old 10-19-2013, 11:40 AM Thread Starter
Quoted: 31 Post(s)
Thx Rob, appreciate it
post #4 of 6 Old 10-19-2013, 12:17 PM
BIG Laing's Avatar
Use 7500 as the maximum interval. No harm in doing it more often then that.
2013 Lariat Eco-Boost F150 Super Crew 4x4 5K Miles. Max-Tow 3.73's, luxury package
BIG Laing is offline
post #5 of 6 Old 10-19-2013, 09:07 PM
"Stroker 8"'s Avatar
Quoted: 3 Post(s)
I have the 20" Michelins and I rotate every 5K miles.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #6 of 6 Old 10-19-2013, 10:22 PM
Hellobatman's Avatar
If you take it to the dealer to get it done make sure its a good one that knows wtf they are doing. Saw some kid rotate mine at my first service interval and just zapped them back on with the impact gun. Didn't ever check for proper torque nor take the courtesy to balance them. Forbid I get a flat, doubt I'll be able to break the nuts free.
2013 F-250 Lariat FX4, 6.7 Scorpion, All the bells and whistles!
Hellobatman is offline
