Idea for push button exhaust brake - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 10 Old 10-15-2013, 06:49 PM Thread Starter
Alright guys so I have had my truck for almost a year now and pull a 10 000lb 2 horse trailer with living quarters. The truck is also my daily driver.
Frankly i am very dissapointed with the stock "exhaust brake" and have been thinking of ways to make it better. I came accros BD Diesel's controller for the 6.4
BD Power - Product: 6.4L Variable Vane Exh Brake
I dont think it would be very difficult to make one for the 6.7 and here is what I am thinking.
Requirements for it to operate:
Zero throttle position
Less then max exhaust back pressure. Anyone know what this is??
The VGT actuator i believe is electric and hydraulic, please correct me if i am wrong.
We need to make a controller that sends a signal to fully close the vanes if there is zero throttle and less then maximum exhaust back pressure.
Now from what i have read in the 6.7 H and S bible, there is a backpressure sensor but i do not know what kind of signal it sends back to computer (voltage or current) Same thing for the throttle position sensor and VGT actuator.
Does anyone know what these values are?
Also it would be super simple to make it identical to the BD one by tapping into the tow/haul button to achieve downshifting.
Sorry about the long post but lets put our heads together and come up with something!
2012 F350 Dually 6.7 Powerstroke
Full Air Ride Suspension Built and Designed By Myself
6000K HID Headlights
mitchedwards is offline
post #2 of 10 Old 10-15-2013, 06:57 PM
The 6.7 already does this function.
2012 F250 CCSB 6.7 (3.73 gears) H&S Minimaxx (My own tuning), H&S 64mm turbo kit, H&S Dual Fueler, H&S Low Pressure Fuel System, H&S CCV delete, No Limit s2 Intake, PMF 3-link, PMF traction bars, Fox 2.0s, Icon 2.5" coils, Platinum 20s w/ 295/65 toyo at2s, Airlift bags and wireless controller, TFI 50gal, rollX, AMPboards,
jcain is offline
post #3 of 10 Old 10-15-2013, 07:08 PM Thread Starter
I realize the 6.7 already has an exhaust brake but i feel that it does not close the vanes enough in order to increase it's effectiveness.
What i want to do is when the switch is activated, it fully closes the vanes until the max exhaust back pressure is reached, then it would open them until exhaust back pressure decrease, then close the veins again etc etc
post #4 of 10 Old 10-15-2013, 07:16 PM
factoryflood's Avatar
That sounds like alot of strain on an already proven weak turbo
2012 F350SRW CCSB
H&S Mini Maxx with MCC, Spartan with war hammer(FOR SALE), 5" down pipe back exhaust, AFE Stg 2 Cold Air Intake, 6k 55w HIDS, Eagle Alloys 014 20x9 0 offset wheels, 35x12.50R20 Toyo Open Country AT2 Xtreme, UWS toolbox
Inside- Pioneer AVH3200BT, 2 Kicker CVT 12's, Kicker ZX1000, 4 gague wiring, Custom sub box, 20% tint all the way around
factoryflood is offline
post #5 of 10 Old 10-15-2013, 07:18 PM Thread Starter
The newer hyper-balanced ones seem to be stronger and under stock conditions i dont think it would be a problem. but i am not a turbo expert by any means.
Does anyone know the max exhaust back pressure for the 6.7?
post #6 of 10 Old 10-15-2013, 07:20 PM
I like the idea. I think the turbo is plenty strong if kept within its operating limits. I wish i was more mechanically inclined so i could contribute something.
Firemedzo1078 is offline
post #7 of 10 Old 10-15-2013, 07:38 PM Thread Starter
If anyone knows the following information could you please share it?
Throttle position voltage range and voltage for zero throttle
VGT actuator voltage for fully open and fully closed
Exhaust back pressure voltage readings and max pressure allowed
Thanks!
post #8 of 10 Old 10-16-2013, 05:11 PM Thread Starter
Well guys i found some info about the exhaust pressure sensor from the H&S Bible
70 psi=3.75V
60 psi=3.25V
50 psi=2.7V
The 6.4 can sustain 70psi of back pressure according to BD Diesel so it would be safe to say the 6.7 can handle 60psi?
These values aren't exact but are fairly close from reading off of their graph
If anyone with a H&S tuner that can read the back pressure could you see what you get when the exhaust break is active? Could you also include the boost number associated with it?
Thanks!
post #9 of 10 Old 10-21-2013, 07:50 AM Thread Starter
Does anyone know what the vgt actuator needs for voltage for veins fully open and fully closed?
Thanks!
post #10 of 10 Old 10-26-2013, 06:14 PM Thread Starter
Alright guys i found some info on the vgt actuator
DUTY CYCLE % AMPS
0 0
5 0.425
10 0.45
15 0.475
20 0.5
25 0.525
30 0.55
35 0.6
40 0.65
45 0.6875
50 0.725
55 0.7625
60 0.8
65 0.875
70 0.95
75 1.025
80 1.1
85 1.2
90 1.3
95 1.4
100 1.5
So after finding this out i cut the wire from the vgt actuator, ran it to my multimeter, then back to the pcm.
I did some driving around town today with no trailer and found at idle it is at 85% duty cycle, driving around in stop and go traffic ranges from 60 to 85% duty cycle. i went down some decent hills, downshift into 4th so rpms were above 2500 and what did i notice??? The vgt duty cycle ranged from 45 to 60%!!! this did generate a peak of 4psi of boost and held 3 psi of boost.
So from these findings it appears ford does not close the veins for exhaust braking... is that false advertising on their part?
On the plus side this means i can improve the exhaust braking with my controller i am thinking of!
Does anyone know what backpressure this engine can handle before valve float occurs?
Thanks
Mitch
