So Ford tells me I'm SOL with tire size - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-14-2013, 07:35 AM Thread Starter
Ok..I'm putting a Carli levelling kit on my '11 F250...stock tires are the 275/65/20s...only going up to either 295/65/20 or 35x12.50....stock tire is 34.1 inches roughly...is it me or should this be any easy adjustment by a Tech? I was told when I bought the truck, going up one or two sizes would NOT be an issue...(now 2 dealerships have said sorry about your luck) I'm not worried about the speedo being off, I just know that all the goodies on the drivetrain are precise....is going up to that size tire really a concern? If so, what is the best way to get it programmed? I'm not looking to super mod my truck, I just want everything shifting at the right time and the speedo correct if possible...thanks guys...any help is much appreciated.
SCBigJon is offline
post #2 of 9 Old 10-14-2013, 07:57 AM
What you're doing has been done thousands of times. Just install the leveling kit, get a good alignment and put on the tire of your choice. No bigger tire than you're putting on the speedo shouldn't be off by more than a mile per hour or so. I've yet to ever have any problems out of mine. Enjoy
claws314 is offline
post #3 of 9 Old 10-14-2013, 08:00 AM
I'm running toyo 35x12.5 with no issues in summer and 295/65r20 toyo at2 extreme in winter. (Also leveled) According to GPS speedo isn't even off 1mph. Just lost a few mpg with the bigger/ heavier tires.
2011 F-350 CC King Ranch Leveled
Dustin379L is offline
post #4 of 9 Old 10-14-2013, 08:17 AM
Quoted: 2 Post(s)
Feedback Score: 5 reviews
You don't need any level kit to run 35"
I would look at adding Castor shims to gain the needed castor for these trucks.
CT Performance, Inc. is offline
post #5 of 9 Old 10-14-2013, 08:19 AM
WoodBoy's Avatar
You have no worries. People run 32"-40" tire sizes on these trucks daily on stock everything (besides lifts or lowering kits).
I would look at radius arm drop brackets such as the ones from Trevor @ PMF (precision metal fab) over caster shims. He makes the drop brackets from 2.5" and on up
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
http://www.powerstroke.org/forum/6-7...ustration.html
http://www.powerstroke.org/forum/6-7...round-2-a.html
WoodBoy is offline
post #6 of 9 Old 10-14-2013, 01:20 PM
tmd
I put 325/60r20 GY Duratrac's on without issue and since added a 2.5" leveling kit. BTW these tires measure out at 35.4" x 13" so they are slightly bigger then the average 35x12.5
tmd is offline
post #7 of 9 Old 10-15-2013, 07:11 AM Thread Starter
I am putting new tires on at the end of the week. Will a 35x12.50/20 fit safely on the stock 20" wheels? I am sure this has been asked numerous times....I noticed on Toyo's website that they recommend 8.5, 9.0 or 9.5 width wheels for the 35x12.50s. Are the stock 20" wheels 8" wide?
SCBigJon is offline
post #8 of 9 Old 10-15-2013, 07:22 AM
tmd
There's plenty of folks on here running those tires on the stock wheels.
tmd is offline
post #9 of 9 Old 10-15-2013, 07:36 AM
Axis2011KR's Avatar
Yes they will be fine and the stockers are 8" wide. The only issue you might have is the installer for example (Discount Tire) won't mount them because they don't meet manufacturer recommended widths. I had this problem when I had my 35x12.50x18's put on my stockers. You might get a little uneven wear from the narrower rim but it's not bad from what I've seen.
2015 F-250 King Ranch 6.7L CC FX-4
Fabtech 10" 4 Link with Coilovers/American Force Vector 22x12/Toyo MT 40x15.50x22
SCT+No Limit+FloPro
2011 F-250 King Ranch 6.7L CC 4x4 sold
H&S+S&B+Open Downpipe
Axis2011KR is offline
