ball mount drop - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 12 Old 10-12-2013, 05:58 AM Thread Starter
ball mount drop
newbie question:
I have a 2011 F350 that I use with a 5th wheel to tow a camper. I would like to get a ball mount and ball for the factory installed receiver. The height of the center of the receiver is 21". I do not have a specific trailer that I would like to tow, but it would most likely be a UHaul. My question is what drop would be most appropriate for general use? Also, any recommendations for (1) brand and (2) a web site with a good price?
thanks.
jepalmer is offline
post #2 of 12 Old 10-12-2013, 02:37 PM
DSL_PWR's Avatar
Quoted: 9 Post(s)
I think I have a 4" or 5" drop on mine. I can measure it later. I don't remember brand but bought mine at local trailer shop and it is rated for 18k lbs.
DSL_PWR is offline
post #3 of 12 Old 10-13-2013, 01:46 PM
Quoted: 4 Post(s)
Go get the B&W adjustable drop ball hitch. Three chrome balls and pins to adjust 6 to 10 inches vertically. Its a bit pricey but totally the way to go. I'm impressed.
golfpineacres is offline
post #4 of 12 Old 12-19-2013, 09:12 AM
Crazyfrog's Avatar
I run a 2" drop on mine. It works well for a landscape trailer and fishing boat. I have pulled a car hauler a few times and end up using a straight receiver for my 2 5/16" ball.
I don't have a lift, stock height.
2012 CCSB 4X4
XLT - 3:55 6.7
Mini Max-S&B intake
305/65/18 Falkens
Weather guard toolbox
Crazyfrog is offline
post #5 of 12 Old 12-19-2013, 01:28 PM
MuscleBob26
Guest
Posts: n/a
Quoted: Post(s)
This article I found really goes into detail about ball mounts and what you might need here Hopefully it will help you as much as it helped me.
www DOT hitchanything DOT com/How-To-Measure-What-Size-Ball-Mount-You-Need.html
post #6 of 12 Old 12-20-2013, 06:11 AM
Most trailer manufactures want the top of ball 20 inches from ground with empty truck before hitching up. Trailers are usually designed for a hitch height of 18 inches to top of ball. This allows a two inch sag after hitched and weight is on truck.
I think you would be fine with a two inch drop receiver then after you bolt the ball on it would return to your 21 inch height you have now. Hitch height is measured to top of ball.
Whatever you buy, keep it on the truck at all times for extra protection if you get bumped in the rear or back up into a wall. I have saved my rear bumper several times by having my receiver in place. Been hit in stop and go traffic twice with zero damage to my trucks, the hitch saved me. Those adjustable hitches mentioned above give even more protection for this as they have a lot of vertical metal. I have my receiver/ball installed even when I pull my fiver.
You can find what you need at any Bass Pro Shop, I believe they sell Reese equipment if I remember correctly. They will have lower price than a hitch shop. All receivers and balls are stamped with load rating right on them.
2012 F450 Ultimate Lariat pkg, 4X4, FX4, 5th wheel prep, camper pkg, 40console40 seat, Ingot Silver and Black guts
Reese Elite 18k 5th wheel
BedRug liner
DuraFlap flaps all 4 corners
60 gal aux tank in bed
7.4 mpg as shown @ 70mph and 25740 lbs gross!!
2012 Fuzion FZ310 Monster Edition Toy Hauler 12,500 dry 16,500 loaded to play. 3100/3500 pin weight
Breast feeding is a hard habit to quit
mowdoc is offline
post #7 of 12 Old 12-20-2013, 07:55 AM
Str8Ugly's Avatar
Amazon.com: Andersen Manufacturing, Inc. 3410 2" X 2 5/16" x 5 1/2" Aluminum Drop Rapid Hitch: Automotive Amazon.com: Andersen Manufacturing, Inc. 3410 2" X 2 5/16" x 5 1/2" Aluminum Drop Rapid Hitch: Automotive
are all alum hitches just as good as steel ones?
2011 king ranch f350 cclb 4x4, 6" lift, 20x10 fuel mavericks, 35" toyos, billet grille, ranch hand rear bumper, SCT X4 with PIP tunes, Sinister egr delete, flopro dpf delete pipe
2002 f250 ccsb 4x4
6" pro comp lift kit, 20x10 eagle 064's, 35" trail grapplers, 2007 front clip, Harley Davidson Headlights, Bull nose bumper, Ranch Hand Rear Bumper, dfuser harness, 6637 air filter, straight exhaust, foil delete
Str8Ugly is offline
post #8 of 12 Old 12-20-2013, 08:19 AM
c dog's Avatar
I worked at the worlds largest trailer dealer and sold a ton of the rapid aluminum drop ball mounts. I run one and so does my dad. They are very nice. Never heard any complaints.
Sent from my Nexus 7
c dog is offline
post #9 of 12 Old 12-20-2013, 08:21 AM
Str8Ugly's Avatar
awesome thanks, btw nice avatar
2002 f250 ccsb 4x4
Str8Ugly is offline
post #10 of 12 Old 12-20-2013, 08:29 AM
c dog's Avatar
Thanks. Now if I were to buy a new hitch I would try this instead of the rapid hitch. I like that it has the locks built in and looks nicer. Rated the same as rapid. I have no experience with this brand
http://www.diversi-tech.net/Hitches%20Page.htm
c dog is offline
