2011 F250 shaking/hopping on HWY - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 7 Old 10-08-2013, 06:01 AM Thread Starter
I'm sure this has been discussed multiple times on here...but I have a question. I have 19k on my 2011...no issues thus far until last weekend. I was driving on the highway at about 70mph....all of a sudden out of nowhere the truck acted like I was losing pressure in one tire or I was driving on a gravel road. The truck shook like crazy...thought I would have to pull over and then it quit...lasted about 2 minutes....WTH was that???? Running stock Michelins....which I plan to change very soon.
SCBigJon is offline
post #2 of 7 Old 10-08-2013, 06:33 PM
Look up "death wobble". I haven't had it happen to me, but there are some videos on Youtube and elsewhere that show it. From what I've seen, could be tire pressure or front stabilizer as most likely cause.
Greg
hammong is offline
post #3 of 7 Old 10-08-2013, 07:39 PM
Try balancing and rotating your tires as well.
Rednecktastic is offline
post #4 of 7 Old 10-09-2013, 08:34 AM Thread Starter
I plan on changing the tires soon, so hopefully that takes care of the issue.
SCBigJon is offline
post #5 of 7 Old 10-15-2013, 05:18 PM
Here is your problem......
What WOBBLE?
_______________________________
2003 6.0L F-250 XLT Sport CCSB 4X4
- Lifted
- 35" BFG All Terrain T/As
- AIRAID Intake
- Edge Juice, Insight CS
- 4" MBRP SS Turbo Back No Cat
titanrcr is offline
post #6 of 7 Old 10-16-2013, 08:18 AM Thread Starter
That is insane. Not gettin' the warm and fuzzies after watching those.
SCBigJon is offline
post #7 of 7 Old 10-16-2013, 04:56 PM
If you get under the truck and have someone move the steering wheel back and forth you should see that you have play in the ball joint end of the track bar. Had two friends with low mileage trucks like yours with the exact same problem and both needed new track bars which solved the problem.
So you can put a new Ford trackbar in or go with an aftermarket bar which should take care of it for good.
http://superdutywobble.com/
- Lifted
- AIRAID Intake
titanrcr is offline
