Half million built 6.7. - Ford Powerstroke Diesel Forum
post #1 of 10 Old 09-30-2013, 05:01 PM Thread Starter
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Just got giggles.
Ford Has Built a Half Million F-Series Trucks with the 6.7L Powerstroke V8 | Torque News
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #2 of 10 Old 09-30-2013, 05:49 PM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 15 Post(s)
"-The Unique Inboard Exhaust/Outboard Intake Architecture this industry first in a diesel engine reduces exhaust system volume which leads to improved spool tires and improved power delivery."
I am guessing they meant "times" instead of "tires"?
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #3 of 10 Old 10-02-2013, 12:22 PM
Thats awesome! According to a few all 500,000 of those are gonna break the rods. And the reverse flow heads are awesome, i dont know why its taken so long to use them for turbocharged engines. They make better sense to me
2011 f-250, lariat with nav. 20' dale jr. Racing rims with Mickey Thompson 33" tires. Painted to match grill coming soon. Stock exhaust, waiting for warranty to expire.
nikky_dean is offline
post #4 of 10 Old 10-02-2013, 12:43 PM
Eric@PTP's Avatar
Until Ford came out with a TSB to get an updated ECU reflash that moved the torque band further up into the RPM range they were.
Eric@PTP is offline
post #5 of 10 Old 10-02-2013, 01:03 PM
ciscofreak's Avatar
When did they come up with this flash?
13 F350 Lariat CC LWB
ciscofreak is offline
post #6 of 10 Old 10-02-2013, 01:10 PM
Eric@PTP's Avatar
Not sure on the exact date, but right around a year or so ago ( give / take ). All the tuners pretty much did that too though, the problem with the rods was the low end torque loading up the bottom end to soon. They would either bend or break from there.
Eric@PTP is offline
post #7 of 10 Old 10-02-2013, 01:15 PM
6.0f250firstcar's Avatar
Essentially lugging the engine as if in too low of a gear but it was doing it 100% of the time.
Ryan
6.0f250firstcar is offline
post #8 of 10 Old 10-02-2013, 01:58 PM
ciscofreak's Avatar
Thanks Eric. I have a 13 and it still pulls super strong in the low end. Especially compared to my 6.0.
post #9 of 10 Old 10-02-2013, 02:05 PM
Mines an 11, would they update it if i had brought it in automatically? Ive had it serviced a few times at the dealership now.
post #10 of 10 Old 10-02-2013, 02:12 PM
Eric@PTP's Avatar
No worries, I believe the 13's came with this calibration from the get go.
Thats pretty standard procedure at dealerships, they will search your VIN and it will say the last calibration thats been done. If its older than the most current then they will reflash it to the current version.
Eric@PTP is offline
