how to aim headlights - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 8 Old 09-26-2013, 06:25 PM Thread Starter
so I have had hid's in my stock lenses for about a year( ya ya I know I should of got retrofits) I am getting flashed steady, how does a guy aim his headlights? I would like to point my left one down and to the right a bit...
Bopper is offline
post #2 of 8 Old 09-26-2013, 06:30 PM
RollinEarly99's Avatar
Quoted: 6 Post(s)
Feedback Score: 10 reviews
Find a wall that has at least 50 feet of flat ground behind it. Pull up within 2-3 feet and put an "X" in the middle of each headlight using tape. Then back up straight 50 feet and adjust the head lights right at the "X" marked on the wall. This get all vehicles pretty close!
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 8 Old 09-26-2013, 07:04 PM Thread Starter
i mean how to physically do it, is there a knob to turn or something?
Bopper is offline
post #4 of 8 Old 09-26-2013, 07:05 PM
Quoted: 6 Post(s)
probably should just look in your owners manual for that...
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #5 of 8 Old 09-26-2013, 07:09 PM Thread Starter
yea I could probably dig that out! ill probably end up splurging and getting some custom ones made from plainnsimple eventually
Bopper is offline
post #6 of 8 Old 09-26-2013, 07:18 PM
Quoted: 6 Post(s)
I prefer the Harley Davidson look, blacked out without actually tinting and losing visibility. I took my headlights apart, painted them, then put me back together... Cost $10
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #7 of 8 Old 09-26-2013, 07:38 PM
Hellobatman's Avatar
Should be vertical adjustment screws somewhere in the vicinity of the headlight assembly. Don't remember where they were the last time I had them out.
2013 F-250 Lariat FX4, 6.7 Scorpion, All the bells and whistles!
Hellobatman is offline
post #8 of 8 Old 09-27-2013, 11:33 PM
There is a crazy vertical adjustment screw that takes a philips head screwdriver but you will need about a 3 ft extension to adjust while on the truck. Its located on the inner half of the headlight assembly on each side. Kinda hard to get to. Hope this helps.
Chaas75 is offline
