Cross referenced cheaper (in $) Oil Filter - Ford Powerstroke Diesel Forum
post #1 of 12 Old 09-25-2013, 04:39 PM Thread Starter
2013F250Tank's Avatar
Has anyone cross referenced a oil filter for the 6.7 yet or know why not to use a gas oil filter? I found a Fram Xtended Protection for synthetic oils. Same size and looking, internal an external. Yea or nay or any bad experiences doing this? Its $11 instead of $29.
13 F250 Lariat CC SB 3.31 EL axle w/SPE full lock module, Ultimate Interior,
H&S Big Single 64mm NON VGT Turbo Kit, Cast manifolds, NON Cobra downpipe, Mini MAxx w/H&S stock fuel tune
Down Pipe back 304T 4" Diamond Eye, AFE stage II intake, front 4 link,
Road Armor bumpers front/rear. N Fab nerf steps. 20" American Force w/Trxus 33",
Dura flaps, Air Lift rear bags, 34k+ miles, Stage 3 traction block bars.
2012 F250 TOTALED.
Civilian Contractor Airforce 2+ years Asscrackistan.
2013F250Tank is offline
post #2 of 12 Old 09-25-2013, 04:45 PM
IBEW Journeyman Lineman
PolarBear's Avatar
Motorcraft FL-2051 $12.95 @dieselfiltersonline.com. I have not cross referenced another filter but I personally will only use Motorcraft brand.
2012 F350 XLT CCLB 4x4 6.7
PolarBear is offline
post #3 of 12 Old 09-25-2013, 05:15 PM
Quoted: 11 Post(s)
I buy from Dieselfiltersonline also. For $12.95, why buy an imitation?
I get two oil filters, one fuel filter and one air filter each time I order.
2015 F350 CC SRW LWB Lariat, Leveled, BAKflip, Ultra Predator wheels with Toyo A/T 295/65R20, Firestone Airbags and onboard compressor
2011 F350 CC SRW LWB Lariat - Gone
Painted Horse is offline
post #4 of 12 Old 09-27-2013, 06:35 AM
Wix 57151. But I have only used Motorcraft in mine...
mjz52 is offline
post #5 of 12 Old 09-27-2013, 07:28 AM
Term3's Avatar
There have been nothing but serious problems when guys cheaped out and bought non-OEM oil filters for the 6.0 so why take the chance with your truck? You have a $10G+ engine and your looking for the cheapest oil filter to slap in it? Good luck with that. LOL
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #6 of 12 Old 09-28-2013, 05:18 AM Thread Starter
Not looking for cheaper quality by any means. Stated that in the initial post. You twist the the filter on not " slap it in". Some gas motor oil filters, filter out smaller microns so it would actually be better an cheaper in price. I would just change it every 2500 miles instead of every oil change 5000 miles. the current one i found is $11 but instead of "saving money" like i said i would change more often leaving my motor cleaner then the "oem maintenance" program.
2012 F250 TOTALED.
post #7 of 12 Old 09-28-2013, 07:51 AM
it crosses to a Donaldson P502503
it crosses to a Fleetguard LF17494
poormanscat is offline
post #8 of 12 Old 09-28-2013, 07:54 AM
matty21's Avatar
Nothing good ever happened from cheaping out and putting cheap stuff on your truck. Especially important stuff like filters.
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
http://www.facebook.com/video/video....91500544216050
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
post #9 of 12 Old 09-29-2013, 06:29 AM
Term3's Avatar
Putting in a smaller micron oil filter in the stock location IMO is not a good idea. If you used a smaller micron filter in a remote setup where a larger size filter cartridge could be used then yes go ahead, but going to a smaller micron filter in the stock location is just going to increase the amount of oil that bypasses the filter during cold starts, colder weather and as it collects oil contaminants faster. So you'd actually be making things worse for engine wear. You can't really compare filters used on gas engines to what is used on diesel engines as the contaminate loading for diesels is much higher. If you don't want to put in a remote oil filter setup then just add a bypass oil filter setup such as one made by Amsoil then your filtering out contaminants down to two microns and more oil is going thru the regular oil filter because there isn't a higher differential pressure that causes the bypass valve to open.
Term3 is offline
post #10 of 12 Old 09-29-2013, 06:42 AM
not necessarily, in a lesser quality filter, you are probably right. But high quality filter manufacturers work extremely hard to ensure that the BVOP is consistent for the application specs. while flowing the correct GPM thru their filtering media at a verified test temperature. Pretty much an industry standard on testing conditions.
