Need to lower new truck. HELP!!!! - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-23-2013, 05:26 PM Thread Starter
Just picked-up a 2013 F350 Platinum 4x4 Short Bed, the result of having a drunk driver take-out the passenger side of my 2010 F250.
The new truck sits so high that my fifth wheel trailer is dangerously close to hitting the bed and the front of the trailer is excessively high.
What is the most cost effective way to bring the rear of the truck down 2" to 3"? It would also make the truck sit & look much better.
.....Replace the 3 1/2" blocks with 2" blocks?
.....Lowering shackles? (I can't find any for my truck on the Internet)
.....Run a set of 14" tires & wheels?
Any ideas/solutions would be appreciated!
Truckmaniac is offline
post #2 of 4 Old 09-23-2013, 07:10 PM
MorganM's Avatar
Quoted: 2 Post(s)
I used lowering shackles for an '04 model to lower my '12. You may need the f250 blocks and shackles to get 3".
MorganM is offline
post #3 of 4 Old 09-23-2013, 07:24 PM
alaskan155's Avatar
Quoted: 50 Post(s)
just remove the block all together..... and replace the u-bolts with 2wd ones
the difference in height is between the f250 block and taller f350 block,
removing it all together should level the truck out
2002 F250 7.3/JW Tow master 4r100 203k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range , 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #4 of 4 Old 09-23-2013, 07:25 PM
alaskan155's Avatar
Quoted: 50 Post(s)
also either way you lower it and you have a rear sway bar you are going to need shorter links
