What happened to the gear display? - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 15 Old 09-18-2013, 08:24 AM Thread Starter
On my 2011 there was a display to show what gear the truck was in. It was in the little center screen display. On my 2014 it's not there. Anyone else notice this?
Bruce
2014 F-250 King Ranch
Crew Cab Long Bed
6.7 Diesel
spur of the Moment is offline
post #2 of 15 Old 09-18-2013, 08:43 AM
ATCguy's Avatar
Tap your +/- Manual Shift buttons on the Shift Handle... they'll show up.
Tom
2014 F-450 PLATINUM
2014 Dutchmen Voltage 3200 5th Wheel Toy Hauler
2007 Honda GL1800A Gold Wing
ATCguy is offline
post #3 of 15 Old 09-18-2013, 08:45 AM
Its there. Push the + sign on the gear shifter, it should pop up. You can turn it on and off by pushing the + button.
Sent from AutoGuide.com App
2012 F250 Lariat CCSB FX4, Gooseneck and 5th wheel prep package, H&S Minimaxx, 5" AFE SS straight pipe, EGR delete with factory EGT sensor, 35" Toyo MT's on stock rims, and Bilstein 5160 shocks.
thomaslord84 is offline
post #4 of 15 Old 09-18-2013, 09:05 AM Thread Starter
Hey thanks....I'll try it.
Crew Cab Long Bed
6.7 Diesel
post #5 of 15 Old 09-18-2013, 09:24 AM
WoodBoy's Avatar
Make sure its in park when you push the +/- button
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
http://www.powerstroke.org/forum/6-7...ustration.html
http://www.powerstroke.org/forum/6-7...round-2-a.html
WoodBoy is offline
post #6 of 15 Old 09-18-2013, 09:30 AM
That doesn't matter. The "-" doesn't toggle the gear display. It will only toggle the gear display in Drive "D" if you press "+" for on or off after it reaches "6". It won't even show up in Park "P".
2013 F350 Lariat Ultimate FX4 CC LB SRW
jetskier is offline
post #7 of 15 Old 09-18-2013, 09:37 AM
WoodBoy's Avatar
Ahhh. Idk why I thought I couldn't get it to pop up unless I did the +/- in neutral or park
WoodBoy is offline
post #8 of 15 Old 09-18-2013, 09:53 AM
Mine doesn't stay on any longer after having the dealer perform the trans reprogram for a TSB. I have to turn it on everytime I put it in drive now.
2012 F-350 Crew Cab Lariat 4X4
H&S XRT Pro; DPF deleted; S&B Air Intake
2006 F-350 Crew Cab XLT 4X4 *SOLD*
hmdavid is offline
post #9 of 15 Old 09-18-2013, 10:00 AM Thread Starter
I'll be going out later and try it.
Crew Cab Long Bed
6.7 Diesel
post #10 of 15 Old 09-18-2013, 11:31 AM Thread Starter
Tried it. Didn't work in park.....put it in drive and pressed the +.....it came on. Comes on each time I start it. Thanks.
Bruce
Crew Cab Long Bed
6.7 Diesel
