Idle Hours - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 11 Old 09-13-2013, 06:06 PM Thread Starter
Idle Hours
I'm retired and have lots of idle hours. I see about 310 engine hours on my Super Duty of which 43 of those are idle hours. I noticed right away I don't get very good mileage while idling. I see some guys hardly ever shut off their trucks; idling while fueling, idling while picking up a six pack, idling while talking to the neighbor, etc.
I idle my truck for about 2 minutes after coming off the highway after pulling for cool down. I also idle my truck for about 2 minutes when starting in sub freezing weather for warm up. And I idle it while positioning and hitching up the trailer. Even at that, I am running about 12% idle hours. This seems high to me.
I wonder what others have for engine hours and idle hours? Is the criteria for idle hours means the transmissiion in park? Or is being stuck in traffic at zero mph while in gear logged as idle hours too?
Less idle, less fuel used.
2013 F350 CC 6.7 4x4 Lariat 3.31
Black, Leer Cap, 18" Wheels
Grandpa's Camper Puller
dbj216 is offline
post #2 of 11 Old 09-13-2013, 06:16 PM
kirbybc12's Avatar
The idle meter counts when the engine is also under a certain RPM either while driving or actually idling. Can't tell you what mine are now but at 25,000 miles I had 96 idle hours. Mine never idles when I hop out unless I'm hopping right back in within 2 minutes
2012 F-350 Lariat FX4 CCSB
2.5" Carli Commuter
Carli High Mount Steering Stabilizer
AFE Cold Air Intake
Truxedo Lo Pro QT
Line-X
Dura-Flap Mud Flaps
Timbren SES
High Idle
35x12.5x20 Toyo AT II Extreme
H&S Mini Maxx, 4" AFE Turbo Back
kirbybc12 is offline
post #3 of 11 Old 09-14-2013, 03:31 AM
Hawkeye Diesel's Avatar
I have 70,000 miles on my 2011, 2000 some odd engine hours and around 360 idle hours.
[/SIGPIC]2008 F250 Lariat, 8" lift 37x12.5 20 Nittos, Spartan tuned running 275 with an AFE stage 2 and 4" straight pipe. Next up, full EGR and Cooler delete
Proud to be a Union Steamfitter
Hawkeye Diesel is offline
post #4 of 11 Old 09-14-2013, 08:58 AM
1stnlast59's Avatar
How do I check engine hrs. I have the lower grade info center
1stnlast59 is offline
post #5 of 11 Old 09-14-2013, 01:04 PM
"Stroker 8"'s Avatar
Quoted: 3 Post(s)
Easy, just run a system check using the left hand steering wheel buttons.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #6 of 11 Old 09-14-2013, 04:59 PM Thread Starter
Hawkeye appears to run about the same precentage as I do for idle hours. I want to protect the turbo from over heating, and I need to warm the oil on cold winter days.
On cold days the PCM commands about 900 rpm at idle. I'm surprised rpm dictates the idle hour. Some guys run a high idle program to drive an accessory from the 6 bolt on the transmissiion, like a hydraulic puimp. I suppose this condition the engine is "working", not idling even though the travel speed is zero.
Thanks for the input.
dbj216 is offline
post #7 of 11 Old 09-14-2013, 06:24 PM
2013F250Tank's Avatar
Engine hours for my 2013 are 672 and idle hours are 306. Very excessive i know but i let her warm up, cool down an unless its over a 30 minute stop she runs.
13 F250 Lariat CC SB 3.31 EL axle w/SPE full lock module, Ultimate Interior,
H&S Big Single 64mm NON VGT Turbo Kit, Cast manifolds, NON Cobra downpipe, Mini MAxx w/H&S stock fuel tune
Down Pipe back 304T 4" Diamond Eye, AFE stage II intake, front 4 link,
Road Armor bumpers front/rear. N Fab nerf steps. 20" American Force w/Trxus 33",
Dura flaps, Air Lift rear bags, 34k+ miles, Stage 3 traction block bars.
2012 F250 TOTALED.
Civilian Contractor Airforce 2+ years Asscrackistan.
2013F250Tank is offline
post #8 of 11 Old 09-14-2013, 06:43 PM
I was told by local dealer. All RPM's below 1000 are idle time. Either in drive,park,reverse. Doesn't matter
nomad41 is offline
post #9 of 11 Old 09-16-2013, 05:02 PM Thread Starter
Thanks Nomad.
I couldn't find anything in my owners manual on idle hours. I am now at 375 engine of which 43 are idle. My truck will move about 5 mph at idle, which I do in RV parks, etc. I guess that counts as idle hours.
dbj216 is offline
post #10 of 11 Old 09-16-2013, 05:32 PM
yall aint got crap for idle time hours... Ill get a pic of mine and post for ya!!.
poormanscat is offline
