Truck mpg vs "hand calc" mpg - Ford Powerstroke Diesel Forum
post #1 of 23 Old 09-09-2013, 05:34 PM Thread Starter
Just wondering what procedure you use?
I am always seeing folks fussing about the "Truck" lying and how much better the hand calc is. So, how do you do it?
2013 F 350 King Ranch all stock
Big Tex 14 GX Dump Goose neck Trailer 14k GVWR
25' Flat bed Dovetail Goose neck Trailer 16k GVWR
M 101-A2
Traxx is offline
post #2 of 23 Old 09-09-2013, 05:40 PM
Ordnance on coordinates
powerstrokeshellback's Avatar
Quoted: 50 Post(s)
Feedback Score: 7 reviews
Miles driven divided by gallons to fill.
2007 Ford F-250 XL 6.0L Powerstroke 4x4
God bless America, the Constitution and the Second Amendment.
Archoil gangbang - don't be the soggy biscuit
powerstrokeshellback is offline
post #3 of 23 Old 09-09-2013, 05:41 PM
SuperCrutyPS's Avatar
Quoted: 258 Post(s)
Garage
Fill up your tank.
Drive a distance (you choose).
Fill up your tank. Observe how many gallons it takes to fill up.
Divide the miles you drove by the gallons you filled up with.
Example: You drive 200 miles and you put in 10 gallons.
200 divided by 10 equals 20 mile per gallon.
Owner | Operator: Darryl
My Truck Garage: Ol' Guy
Tow Toy Garage : Pilgrim International 31RE3SLF5
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #4 of 23 Old 09-09-2013, 05:43 PM
broncojason's Avatar
My computer is usually reading 1mpg higher than what I calculate.
2012 F250, Tuxedo Black, CCSB, 3.31, Banks Automind, leveled, Nitto Trail Grapplers.
broncojason is offline
post #5 of 23 Old 09-09-2013, 05:47 PM Thread Starter
Oh, Im not talking about the math. That is simple. What I'm getting at is how do you know that your hand calc is correct? If your going off of the trip or odometer how do you know that the calibration is correct? How do you know if you put in fuel to the exact same level the second trip to the pump?
M 101-A2
Traxx is offline
post #6 of 23 Old 09-09-2013, 05:55 PM
Quoted: 258 Post(s)
Garage
A couple of different ways to check the trip meter.
1. GPS unit - Probably the most accurate.
2. Find a highway that has mile markers on it.
Fuel fill up.
1. You could fill to till the pump clicks off the first time. Drive your distance, but make it possible to come back to the same pump and do the same thing.
2. Fill your truck until the fuel is at the top of the filler neck, drive around and fill it up the same way.
post #7 of 23 Old 09-09-2013, 06:14 PM Thread Starter
Thanks, I agree. The GPS can also be used to verify your speedo and if that is correct then your trip and odometer will be as well. Most OEM GPS units will however use a speed input from the vehicle and throw your calcs off that way. A stand alone GPS would be a good idea. Another thing to remember is to fill up at the same time of day and fill slowly to avoid foam up and vapor expansion.
M 101-A2
Traxx is offline
post #8 of 23 Old 09-09-2013, 07:00 PM
I'm not totally convinced that the speedometer and odometer are perfectly synced. My speedo reads 1mph slow going off my GPS at 55mph, but when Im watching mile markers, I'm off by over a tenth in a mile.
post #9 of 23 Old 09-09-2013, 07:19 PM
I_AM_RP3's Avatar
I have a handheld GPS unit and I used it a while back. I had it on my dash for clear satellite view. I reset my trip on my truck and on the GPS and over a 20 mile trip the GPS said 20.3 and the odometer said 20. And my speedometer was 2mph off. GPS said 73, and cruise was set at 75.
Sent from my DROID RAZR
I_AM_RP3 is offline
post #10 of 23 Old 09-09-2013, 07:25 PM Thread Starter
Look at it as a percentage. 1 mph is 1.8% or to round up approx 2% at 55. Now 2% is no where near a tenth of a mile but its hard to keep a eye on 2 things at the same time specially with one in the truck and one out side and 10 ft away. Try getting the distance with your GPS as well.
M 101-A2
Traxx is offline
