F450 Economy - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-07-2013, 05:57 PM Thread Starter
F450 Economy
Greetings,
New member here. I've had 2, 7.3's; an 89 and a 96. My current truck is a 2004 F350 6.0 Chassis Cab (regular cab) with a 8 x 12 aluminum bed. It has a 6 speed manual and 3.73 gears. I use it mostly to haul honey bee hives and also to tow a boat (8,000 lbs) from North Dakota to Louisiana each year.
I'm looking to get one of the new F450's (Supercab) with an 186 inch frame so I can have the same or similar 8x 12 aluminum bed. I plan to get the Lariat with 4:10 gears (as high as they go apparently?). Any of you great members have any guess what kind of mileage I might get? I had hoped to get a 350 but I can't get a Supercab with the wheel base needed for the bed I need. I get along just fine with 3.73 gears in my old truck but I did had to beef the springs up to support the weight I haul. The 450 shouldn't require any modification.
I thank you in advance for the sage advice of the forum members
Chip Euliss
Chip Euliss is offline
post #2 of 9 Old 09-07-2013, 06:15 PM
WNY Biodiesel Co-op
greasyF250's Avatar
4:10 will cut your fuel mileage , hard to say how much,at least 1 mpg
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
post #3 of 9 Old 09-07-2013, 07:39 PM
Quoted: 2 Post(s)
Mileage is bad. Empty 12 loaded 9-10.
swiseuf is offline
post #4 of 9 Old 09-08-2013, 02:37 PM
My 2012 F450 crew cab with 8 foot bed and 430 gears will do about 13 empty, , , 14 if you let the cruise control go at 60mph. Pulling a 38 foot toy hauler weighing around 16k will bring that down to between 6.5 and 7.5 mpg depending on speed.
I gotta ask - - why would you even be concerned with fuel mileage on a truck this size?? Sorry, had to ask.
2012 F450 Ultimate Lariat pkg, 4X4, FX4, 5th wheel prep, camper pkg, 40console40 seat, Ingot Silver and Black guts
Reese Elite 18k 5th wheel
BedRug liner
DuraFlap flaps all 4 corners
60 gal aux tank in bed
7.4 mpg as shown @ 70mph and 25740 lbs gross!!
2012 Fuzion FZ310 Monster Edition Toy Hauler 12,500 dry 16,500 loaded to play. 3100/3500 pin weight
Breast feeding is a hard habit to quit
mowdoc is offline
post #5 of 9 Old 09-08-2013, 03:09 PM
Would backing down to a F250 with 3.55's and a good trailer work for you?
claws314 is offline
post #6 of 9 Old 09-08-2013, 05:11 PM Thread Starter
Smile
Not really concerned about the mileage, more curious than anything about how it would compare with my 350 and 3.73 gears. I get about 13 unloaded and 9-10 pulling an 8,000 lb boat. Most of my miles are written off as a business expense. A load of honey will weigh in about 7,000 lbs but I don't have to haul it more than 10 miles or so. I had to beef up the springs in the 350 but I'd think the 450 would carry the load fine. A load of bees is less, maybe 5,000 lbs or so. A trailer wouldn't work for me since I pull a trailer with an all terrain forklift when hauling bees from place-to-place.
post #7 of 9 Old 09-08-2013, 05:13 PM
jesilvas's Avatar
That would be a recipe for overloading the truck.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #8 of 9 Old 09-08-2013, 06:11 PM
How is 7000lbs on a trailer going to overload the truck?
claws314 is offline
post #9 of 9 Old 09-08-2013, 06:23 PM
jesilvas's Avatar
I'm saying getting a smaller truck and axle ratio and a large enough trailer, that is easier to overload.
4R100, 2wd
330,000 + miles
jesilvas is offline
