TIME TO CHANGE SHOCKS ?????? - Ford Powerstroke Diesel Forum
post #1 of 41 Old 09-01-2013, 10:01 AM Thread Starter
I have a 2013 F-350 cc fx4 4x4 6.7, it rides good but has highway hop at times, just depends on road, Had the factory 275/65/20 MIchelin ltx tires replaced after filing a complaint to the BBB because they hade cracks in them @ 3000 miles. by the way you wont get anywhere getting them replaced any other way. Dealer installed goodyear ATS wranglers at my request. I have heard the factory rancho's are trash from new, also heard that bilsteins made a world of difference. called bilstein they said the 5100s were not for a non lifted or non leveled truck, said do not use anything but the yellow 4600 series if im not leveling the truck. any input is greatly appreciated. also where is the cheapest place to order from.
VACARELLAB is offline
post #2 of 41 Old 09-01-2013, 11:12 AM
"Stroker 8"'s Avatar
Quoted: 3 Post(s)
I just installed Rancho 9000XL shocks and a Bilstein 5100 steering damper. The stock rancho's that come with the FX-4 offroad pkg. are Junk! After the install the difference in ride is Huge! I went thru Amazon ad got a great deal on both. Good luck and let us know how it turns out.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #3 of 41 Old 09-01-2013, 11:21 AM
i put icons on my truck and it rides better then most cars
05 f250 harley edition
studded, deleted
icon shocks with 6in fabtech
sinister coolent filter
sct and ficm tuned
blue spring mod
powermax turbo
175cc
airaid intake
4in turbo back exhaust
black windows
busaandy is offline
post #4 of 41 Old 09-01-2013, 05:45 PM
Summit Racing Equipment is a Bilstien dealer, they also price match anything you can find. I put 5100 series on my 06 Dodge that is not lifted/leveled, actually put 5100s all around, WOW what a difference.
poormanscat is offline
post #5 of 41 Old 09-01-2013, 10:44 PM
79_bronco's Avatar
I just put on Bilstien 5100's all around to replace my FX4 Rancos (with 6000 miles on them). There was a definite improvement but I probably should have waited until the Ranchos were more worn out.
2012 F-250 Lariat Crew Cab Short Bed 4x4 FX4
Ranch Hand Front and Rear
30in Rigid E Series Light
Bilstein 5100 Series Shocks
Truck Cover USA American Work Cover with Toolbox
Kenwood DNX570HD Head Unit
79_bronco is offline
post #6 of 41 Old 09-02-2013, 06:25 AM
DSL_PWR's Avatar
Quoted: 9 Post(s)
Check out fox shocks.
DSL_PWR is offline
post #7 of 41 Old 09-02-2013, 06:49 AM
Whats the Part number for stock height shocks for the rear in 2011-current F350s?
2004 F350 PSD
8" Icon, Loud Pipe, 58v FICM, Deleted, MudGrapplers, Edge Insight, Sct tuned by Vivian.
2011 F350 PSD
AFE , Airbags, Recon, BMF , Nitto,
20046.0 is offline
post #8 of 41 Old 09-02-2013, 07:17 PM
Originally Posted by VACARELLAB View Post
I have a 2013 F-350 cc fx4 4x4 6.7, it rides good but has highway hop at times, just depends on road.
Interesting! I too have a 2013 F-250 CC Platinum FX4 4x4 6.7 with just under 5000 miles and have a highway/freeway hop. I will be following this thread as the hop gets annoying on our last couple of long drives. Love the car but would like to get rid of that hop which feels like the tires are out of balance or something.
loves2travel is offline
post #9 of 41 Old 09-02-2013, 07:28 PM
Raul@Stealth Automotive's Avatar
Raul@Stealth Automotive is offline
post #10 of 41 Old 09-02-2013, 08:16 PM
kirbybc12's Avatar
I'll be putting on 5100s this Sunday along with my Carli 2.5".
If your hop is mostly in the back and over bumps you could look into a Timbrens SES. I installed one two weeks ago and have had a lot less bounce in the rear over bumps.
2012 F-350 Lariat FX4 CCSB
2.5" Carli Commuter
Carli High Mount Steering Stabilizer
AFE Cold Air Intake
Truxedo Lo Pro QT
Line-X
Dura-Flap Mud Flaps
Timbren SES
High Idle
35x12.5x20 Toyo AT II Extreme
H&S Mini Maxx, 4" AFE Turbo Back
kirbybc12 is offline
