2013 F250 Drooping Rear Suspension when loaded - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 5 Old 08-29-2013, 05:17 PM Thread Starter
RedBKM's Avatar
I may be crazy but I've never seen a 3/4 truck sag this bad. I installed a slide-in tool body and it must have dropped 2 inches and looked awful. I also have a heavy Warn brush guard and a M12000 winch. You would think the extra weight up front would level it out but it doesn't. It is still about 1/2" lower in the rear.
This same body and winch previously rode on a '08 F250 and that truck sat 1 inch higher in the rear than the front.
Why does this model droop so bad? What can I do to fix it? I've seen a 1 inch add-a-leaf kit but my last add-a-leaf springs eventually cracked in the center.
2006 F350 PSD Lariat 4x4 SRW, 4" MBRP straight pipe, SCT X3 w/ ID Tunes, Edge Insight CTS, Sinister Coolant Filter, High Idle, Red
2013 F250 6.2L 4x4 (work truck) Factory E-locker, Warn Trans4mer M12000
1995 Mustang Cobra 5.0, Heads, intake, 65mm TB, headers, exhaust, 3.73s, Cobra Rs, 160k trouble-free miles, Red
2011 Mazda Tribute (Ford Escape) 2.5L, 4x4 & 27mpg= Thank you Ford, eBay heated seats, Red
'42 International K1 pickup, Green Diamond I6, 4 on floor, Red
RedBKM is offline
post #2 of 5 Old 08-29-2013, 05:56 PM
BIG Laing's Avatar
Air bags are in your future. There is a thread every week or so with someone commenting on the sag/dropp of the 6.7's
2013 Lariat Eco-Boost F150 Super Crew 4x4 5K Miles. Max-Tow 3.73's, luxury package
BIG Laing is offline
post #3 of 5 Old 08-29-2013, 09:17 PM
its not only us fords...dodges look like there humping a football too, I myself went with firestone airbags after my first tow with the truck
Bopper is offline
post #4 of 5 Old 08-30-2013, 01:31 PM Thread Starter
RedBKM's Avatar
I'd like to install a taller block but I'm not sure if thats easy to find. My F350 has two more leaves but I cant afford to buy new leaf packs.
How do the airbags perform off road? I drive a lot of mountain gravel roads that really flex it out. Do you deflate them to maintain flexibility?
RedBKM is offline
post #5 of 5 Old 08-30-2013, 03:30 PM
try Roadmaster Active Suspension
poormanscat is offline
