2012 w/ 6.7 looking for thoughts on it..... - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-18-2013, 03:43 AM Thread Starter
First time poster here,
Bought a 2012 with the 6.7 in it yesterday after quite a bit of looking and a fair amount of research.
Truck has about 33,000 miles on it.
I am looking for some advice as far as things to be keeping my eye on with it.
Don't want to go looking for trouble, just peoples thoughts.
I am aware of the need to keep the fuel filters changed.
Am also curious about what DPF is and wondering if someone could give me further understanding about how DEF and the DEF system works.
Thanks.
Don McDonald
Don McDonald is offline
post #2 of 7 Old 08-18-2013, 04:54 AM
daystrom's Avatar
Quoted: 2 Post(s)
I too just bought a 2012 that had 36k miles on it.
I would recommend changing the oil, oil filter, air filter, and fuel filters unless you know exactly when they were done last. That way you know they have been changed and are on your schedule then. You can get all the filters (Motorcraft) online cheaper than at the dealer. I think I paid $90 for all three sets.
Fuel quality is very important. Keep the fuel filters changed, fill up with good quality fuel, and use a fuel additive like Diesel Kleen to keep the pumps lubricated. Also drain the Diesel Fuel Conditioning Module (DFCM) once a month and inspect the fuel for water. The DFCM is mounted to the frame under the drivers side door.
Keep an eye on the main high temp radiator especially on the bottom drivers side near the drain. They are prone to leaking there. I had my radiator replaced a few weeks after buying the truck because it was leaking. Luckily I had 200 miles left on the warranty! No warranty, plan on a $1,500 fix
The DPF or Diesel Particulate Filter traps soot in the exhaust. After a while ~200 miles the filter will need cleaned. The truck does this by injecting raw fuel into the exhaust which increases the temperature in the DPF to over 1,500 f. This burns the soot into ash which is then blown out (correct me on that last point if wrong).
This process takes about 10 miles and your fuel economy goes down while it's happening. I normally get around 18.5 mpg but it drops to about 12 during the active regeneration.
If the truck is being run hard and the exhaust temperature is above 570(?) f, passive regeneration takes place without the fuel dumping into the exhaust.
The Diesel Exhaust Fluid gets mixed into the exhaust before the DPF in the Selective Catalytic Reduction (SCR). It's job is to lower NOx levels in the exhaust. It's always happening. Usually you can go about 8000 miles before having to fill it up. You'll get a warning on your dash long before you run out.
Hope this helps!
2012 F-350 Lariat 4x4 6.7 PSD
Platinum metallic / adobe accent
"Sir Topham Hatt thinks I need to learn. He is mistaken. We Diesels don't need to learn, we know everything. We come to a yard and improve it. We are revolutionary!"
daystrom is offline
post #3 of 7 Old 08-18-2013, 01:26 PM
Ajc722's Avatar
I agree with the diesel additive. I use it every other tank and notice my MPG is a little better when I use it. 18.5 without and 19 to 20 with. I also don't drive faster than 70 mph. Congrats on the truck. These are truly exceptional machines.
Ajc722 is offline
post #4 of 7 Old 08-18-2013, 01:44 PM
RAINEY's Avatar
Congrats on the new truck. I bought a 2012 about 1 1/2 monts ago and love it.
Jason
2012 F350 SRW Bought new with 550 miles on it in July 2013
RAINEY is offline
post #5 of 7 Old 08-18-2013, 02:16 PM
Quoted: 4 Post(s)
Congrats. I've had my 2013 for a month now and love it. I also use diesel kleen in every tank. Seems to space out the regens a bit so it helps with mileage.
Sent from AutoGuide.com App
Deerhunter4 is offline
post #6 of 7 Old 08-18-2013, 02:38 PM
ucpa111's Avatar
Quoted: 2 Post(s)
Congrats. Love my 2012. Lots of good info above!
2012 F350 CCLB 3.55 ELD with 20s. Lariat package, Chrome, FX4, Clearance Lights, Rapid Heat, Two Tone, Upfitters, HD Alternator, 5th Wheel prep, Truxedo Lo Pro Tonneau. Linex. On board air and shocker XL train horns.
THIS THING ROCKS!
ucpa111 is offline
post #7 of 7 Old 08-18-2013, 05:22 PM
Area81Racing's Avatar
Same here, bought a 2012 6.7 w/ 9899 miles, this is all good info!
2012 F250 6.7 PowerStroke 4x4 Black
www.Area81Racing.com
Area81Racing is offline
