goodbye ram hello ford - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 13 Old 08-10-2013, 04:34 PM Thread Starter
Well after months of searching and asking questions I finally traded the ram off and bought a 2011 f350 drw lariat and love it. Any tips on maintaining this as well as the def fluid and what not. How often should I drain the fuel filter etc.
2011 F350 DRW lariat Spartan tuned, 4" straight piped exhaust,afe stage 2 CAI,SDP egr delete and more coming
Sold 12 ram 2500 and dont miss it!!!
E99 F350 7.3L parts on the way
skinnysfd is offline
post #2 of 13 Old 08-10-2013, 05:05 PM
congrats! im sure you will enjoy it
Bopper is offline
post #3 of 13 Old 08-10-2013, 05:08 PM Thread Starter
So far its amazing compared to my rams. Power torque jeez and not to mention better mileage so far. Im very impressed just not sure on the urea and the maintainence yet . Ill posts some pics later on
post #4 of 13 Old 08-10-2013, 05:23 PM
I_AM_RP3's Avatar
Browse around, you'll find just about every answer you need. As far as DEF, I've had my truck for almost 3 months and 3400 mikes and my DEF just said it was below half, so about every oil change. Fuel filters should be done every other oil change, 15K miles, and as far as draining the fuel water separator, I do mine almost monthly just to be safe. But definitely read that diesel supplement provided to you. I found mine very helpful and informative since this was my first diesel. Good luck and welcome to the site.
I_AM_RP3 is online now
post #5 of 13 Old 08-10-2013, 05:25 PM Thread Starter
I run power service additive with every tank on my other 3 diesels can I run that in this truck too or will that damage the system
post #6 of 13 Old 08-10-2013, 05:56 PM
I_AM_RP3's Avatar
I'm not familiar with that brand. I run motorcraft cetane booster. I know a lot of guys on here run various additives, diesel kleen, and optilube are a couple that I see the most.
post #7 of 13 Old 08-10-2013, 06:02 PM
back in the saddle
shu873's Avatar
Diesel Kleen is Power service. It's just the gray bottle that doesn't have any anti-gel properties like the white bottle does. It's fine in your 6.7. There are better brands out there that work better and cost more, but tough to beat the easy availability and price of the power service brand.
Kurt
shu873@powerstroke.org
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
post #8 of 13 Old 08-10-2013, 07:58 PM Thread Starter
Cool also do u guys carry bottles of the urea with ya just in case and if so is there a perferred brand or they all pretty much the same .
post #9 of 13 Old 08-11-2013, 06:12 AM
Quoted: 4 Post(s)
I bought a 2.5 gallon container of DEF that I keep in my toolbox just in case. Mine seems to use 1 gallon every 1000 miles so far. Good luck with the new truck.
Sent from AutoGuide.com App
Deerhunter4 is offline
post #10 of 13 Old 08-11-2013, 07:02 AM
Mine also seems to use it at that rate. I stop by the local truck stop and fill up at the pump. Its cheaper and I don't have bottles of DEF sitting around.
John
2013 F-250 6.7L 4x4 Lariat CCSB - Stock for now...
Action H53 is offline
