Re Gear necessary? - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 14 Old 08-08-2013, 05:16 PM Thread Starter
Re Gear necessary?
I have a 4 inch lift and 35" tires. I believe the truck has 3.31 gears. I am looking at getting a 5th wheel camper somewhere between 13-15K. Do I need to have the truck re geared?
thedude1980 is offline
post #2 of 14 Old 08-08-2013, 05:24 PM
BIG Laing's Avatar
You should find out what gears you really have for sure
I think 3.55's would of been the better choice, but don't think you will have any issues with 3.31's and 15K.
2013 Lariat Eco-Boost F150 Super Crew 4x4 5K Miles. Max-Tow 3.73's, luxury package
BIG Laing is offline
post #3 of 14 Old 08-08-2013, 05:26 PM
BIG Laing's Avatar
What size were the rims on the truck stock?
post #4 of 14 Old 08-08-2013, 05:29 PM Thread Starter
Not sure on wheels I bought the truck used. I have the window sticker somewhere and 95% sure it has 3.31 gears. 20 inch wheels with 35" Hankook Dynapro ATM's on it right now.
post #5 of 14 Old 08-08-2013, 06:06 PM
if its got the 3:31 gears, it may pull it, but you are not going to be impressed with the fuel mileage.
poormanscat is offline
post #6 of 14 Old 08-08-2013, 09:00 PM
I tow fairly heavy almost daily and can tell you that a lower gear (3.73 or so) will always be nicer to drive even at the expense of a little lower fuel mileage. Just something to think about if you're going to be towing that 5th wheel a lot.
claws314 is offline
post #7 of 14 Old 08-08-2013, 09:03 PM Thread Starter
Won't be a lot maybe 10-15 trips a year. I would have gotten a 3.53 or 3.73 if I was buying new. Just not sure if the cost would be worth it to change it now. I'm not even sure how much it would cost.
post #8 of 14 Old 08-09-2013, 04:56 AM
I have towed my 13.5K 5'er over six thousand miles using my 3:31 rear end. I get average of 12.3 MPG on the lie-o-meter while towing. Plenty of power, now issues at all. I do have 18" wheels though.
One thing to remember is with that lift, your hitch will need to be adjusted for clearance.
2011 F-350 CC LB SRW Larriet 6.7 PSD with a limited edition rear end bounce @ 43 mph.
thom12 is offline
post #9 of 14 Old 08-09-2013, 05:12 AM
Therabbittree's Avatar
I'm looking for 3.31 gears if you do rear gear.
Thanks,
Deo
2005 EB Excursion 4x4, Gauges, Scan Gauge II, CCV Vented, Zoodad, EGR deleted, rebuild 6.0L, Studded, BPD HD with Winter setup, BPD 58v FICM, Jesse Warren and Gearhead SCT Tunes, Coolant Bypass Lines, Warren 155/30's, Adrenaline HPOP, Wicked Wheel, Rebuilt VGT, Opened Map Width Groove, Diesel Site Boots, Ported and Deleted Intake Manifold, Regulated Return, Bean's Sump, Aeromotive A1000, 4" Stainless turbo back Magnaflow, Custom Front Bumper, Andy Warren Comp Trans, 09 trans pan and filter
Therabbittree is offline
post #10 of 14 Old 08-09-2013, 09:13 AM
I wish Ford would have offered a 3:73 for the SRW from the factory. Seems like it should have been 3:55 or 3:73 option instead of the 3:31.
Swampfox is offline
