How do you verify if your 2011+ has the 400hp/800tq ford tune? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 08-01-2013, 04:38 PM Thread Starter
RamAirfreak98ss's Avatar
Garage
Build sticker was from 1/2011, so not a 2010, but if you cant tell by the build date, any way to verify by hooking a scanner up to it? Any other way to tell?
04 F350 XL
06 F350 Lariat SRW BPD oil cooler, ARP, sinister !egr, s&b intake
06 F350 Lariat C/C DRW 4" Silverline , BPD egr cooler, ARP studs, Garett powermax turbo
07 F550 XL c/c 12' ABC american landscaper
11 F350 Lariat C/C !dpf/doc, SCT 7015
14 F550 Lariat C/C Dump truck, !def/dpf, Flo-Pro, T1 Tuner, S&B intake 3200miles
16 F350 Lariat c/c Nov 2015
RamAirfreak98ss is offline
post #2 of 8 Old 08-01-2013, 04:55 PM
BIG Laing's Avatar
Take it to the dealer to get the update. Even if it wasn't 400/800 to begin with, the update will make it 400/800.
BTW it is free.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #3 of 8 Old 08-01-2013, 07:59 PM
BucOff's Avatar
Any particular TSB# or such that needs to be announced at the dealership for this update?
BucOff (GPDA Member)
Stock Turbo / Stock Sticks
439 rwhp/863 lb/ft.
BucOff is offline
post #4 of 8 Old 08-01-2013, 09:41 PM
BIG Laing's Avatar
They did mine for me when I got my oil changed.
post #5 of 8 Old 08-02-2013, 05:35 AM
"Stroker 8"'s Avatar
Quoted: 3 Post(s)
the easies way to tell is you will see the gear numbers 1-6 illuminated in your display.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #6 of 8 Old 08-02-2013, 06:16 AM
WoodBoy's Avatar
This can be done by hitting the +/- sign on the gear shifter when in park
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
http://www.powerstroke.org/forum/6-7...ustration.html
http://www.powerstroke.org/forum/6-7...round-2-a.html
WoodBoy is offline
post #7 of 8 Old 08-02-2013, 07:31 AM
Mine was updated the day I bought it. That was Sept 2, 2010 so I would assume that yours has it. The unfortunate side was they fried the pcm when they tried to update mine. Signed the papers and was told that I could not take it home for a week!!!
bcangelo is offline
post #8 of 8 Old 10-10-2013, 10:49 AM
Brian S's Avatar
Glad I found this... Took My truck in to try to adress a couple trans issues. also asked if My truck had this 400/800 software and if not please perfom. I was told the tech wanted the 1.0 hour to even check it to see if needed it and I would owe the $125 even if it didnt need it.....I LMAO....I would have paid if it needed it but I declined... Pretty sure He's on here too. I was hoping to try to get in good with him, case of beer or whatever since were in the same industry but I guess not.
2012 F250 6.7 FX4 XLT Crew Cab Long bed (no mods)
Leveling kit with 35' General Grabbers
Brian S is offline
