2013 f350 leveling kit - Ford Powerstroke Diesel Forum
post #1 of 12 Old 07-30-2013, 02:08 AM Thread Starter
richiee23's Avatar
I'm in the market for a leveling kit. I'm not sure what route I wanna go, carli, icon, or just get the spacer, track bar and some bilstien 5100 shocks and call it good. What does everyone else recommend who has a leveling kit. I know I have read on the forums that people are happy either way. Just trying to get a lil more info
richiee23 is offline
post #2 of 12 Old 07-30-2013, 02:13 AM
BIG Laing's Avatar
People who buy spacers usually haven't experienced a true suspension leveling kit like Carli and icon.
So IMO don't go cheap! Carli or icon for sure!
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #3 of 12 Old 07-30-2013, 05:44 PM
Tim250's Avatar
Just installed the carli 2.5" starter kit. I really like it, but havent put many miles on it. Thanks 8lugtruckgear and powerstorke members for all the input. Please don't use spacers
2013 F-250 CCSB Fx4 3.55 Lariat, 17x9 -12mm Fuel Hostage on 315/70 Duratracs, Weather Tech mats, Ellis light bar w/ 8" KC HID's, Carli 2.5" Lift
Tim250 is offline
post #4 of 12 Old 07-31-2013, 05:10 AM
DSL_PWR's Avatar
Quoted: 9 Post(s)
Readylift makes a nice setup for the F350. That's what I have on my truck.
ok big laing, why haven't I experienced a true suspension leveling kit? I wouldn't ever spend that kind of money for a kit from carli or icrap. So explain.
DSL_PWR is offline
post #5 of 12 Old 07-31-2013, 10:23 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Its all about ride quality and long term usage. Cheap kits work for awhile but since they don't address issues from the lift they will start having issues.
Incorrect ways of addressing issues will also have negative impacks.
Lifting these trucks requires a way of recentering the axle, correct way for up to 3" is a adj track bar.
Using spacers under the track bar bracket IMO is insane and using a drop down track bar bracket without a equal droped pitman arm will get you bump steer.
Castor is lost so either radius arm lowering brackets or castor shims are needed.
Using shock extensions in lieu of longer shocks IMO is throwing away $ as stock shocks are crap and you don't gain additional travel that longer shocks will get you.
Icon and Pure performance also have 4 link arm's that allow better ride quality and additional castor that's needed.
CT Performance, Inc. is online now
post #6 of 12 Old 07-31-2013, 05:06 PM
BIG Laing's Avatar
No need for me to explain.
Cartor is lost so either radius arm lowering brackets or castor shims are needed.
Cary already has ^^^ explained perfectly.
post #7 of 12 Old 07-31-2013, 06:36 PM
broncojason's Avatar
Aww, another heated debate about full spring kits or blocks. I think it boils down to how much u are willing to spend.
The full spring kits are very nice. Pricey, but nice. I have set up both styles of lifts, and presently own both styles on different trucks. I have no problem with using a modest spring block; I actually prefer 2" over the 2.5", but as Cary mentioned, there are other things to address.
Firstly, I would definitely use the caster bushings to restore the positive caster. Drop radius arm brackets have the same end result, but I'm not a fan if them hanging down farther from the frame, and losing ur break-over angle ground clearance.
Secondly, centering the axle can be obtained by using the adjustable track bar or drop bracket. The adjustable track bar will allow u to dial it in a bit better, but the drop bracket works well too.
Thirdly, I'd rather just buy new/longer shocks, than using the extensions, but that is an easy change, and can be upgraded later.
As for the rear, I prefer running more leafs than taller blocks, but as long as u don't go over the 4" (3.75") blocks that ford uses in the F350s, I think you're fine. Anything larger, I'd recommend traction bars. Larger blocks will allow more axle wrap, and this is hard on springs, u-joints, etc. I personally run the OEM F350 blocks, and I'm perfectly happy with them.
This is my opinion, based on experience in setting up suspension lifts for years. If I sold high-end kits, then my opinion may be a little more biased.
Do I think u can achieve a very functional lift for less money? Absolutely.
2012 F250, Tuxedo Black, CCSB, 3.31, Banks Automind, leveled, Nitto Trail Grapplers.
broncojason is offline
post #8 of 12 Old 07-31-2013, 08:38 PM
TRENT310's Avatar
I ran a coil spacer and leaf block kit for literally 3 months before I decided I wanted a real lift with replacement springs all around, which improved ride/handling and articulation which are functional benefits of the lift, rather than just the tire fitment and looks that you get from a spacer kit. So I spent even more time and money redoing it after a short time when I should have went for the full kit in the first place.
2011 F-350SD SRW XLT FX4 CCLB: 6.7L PSD, 6R140, 3.55:1 EL, 11500lb GVWR
2009 Tundra SR5 4x2 RCLB 5.7L 4.30:1 (Sold)
Others: 1982 F-250HD 4x2 RCLB 6.9L-IDI // 1988 F-250HD 4x4 SCLB 7.3L-IDI // 1995 F-350HD DRW 4x2 CCLB 7.3L-T444E PSD // 2004 F-350SD SRW 4x4 CCLB 6.0L-VT365 PSD.
VIN details are accurate for the linked truck only, YMMV.
TRENT310 is offline
post #9 of 12 Old 08-01-2013, 03:46 AM
DSL_PWR's Avatar
Quoted: 9 Post(s)
So when should I expect these issues to arise?
I personally have not put enough miles on a truck for find out yet but planned on keeping my '12 for a while. My last truck had a readylift kit installed at 500 miles and I kept that truck until it had 27k miles on it, towed heavy, long highway trips, off-road, etc and never had any issues. I do the same with my F350 which was leveled at 100 miles. So when do I need to be concerned?
I have the readylift 2.5" kit with track bar bracket and am running Fox shocks.
Also why would Ford suggest installing the readylift kit instead of the others mentioned and why would they mention that installing anything other than the spacer kit could void the suspension/drivetrain warranty? Just curious?
DSL_PWR is offline
post #10 of 12 Old 08-01-2013, 11:31 AM
TRENT310's Avatar
Well I'm pretty sure I voided my warranty when I ground off the radius arm brackets with a zipdisc (well, burnt through several) to put in my full lift.
TRENT310 is offline
