windshield washer sprayer... - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 8 Old 07-28-2013, 09:27 PM Thread Starter
ToyoTundra11's Avatar
On my truck, after a couple days (more noticeable 3+ days) of not using my washer sprayer... it takes at least 5 seconds sometimes 10 seconds before water is sprayed out... like the fluid runs back into the reservoir. is this normal?
ToyoTundra11 is offline
post #2 of 8 Old 07-28-2013, 11:09 PM
TRENT310's Avatar
Yeah I've noticed that but also noticed on a variety of different vehicles. Especially if the weather is hotter I suspect that some of it may drain or evaporate. I suppose you can try putting in a check valve to see if that makes it any better but I don't think the few "dry swipes" of the wiper blades, until the sprayers start working, are really that damaging. The hoses under the hood are easily accessible to put in a braid fitting style check valve (probably the ball style).
2011 F-350SD SRW XLT FX4 CCLB: 6.7L PSD, 6R140, 3.55:1 EL, 11500lb GVWR
2009 Tundra SR5 4x2 RCLB 5.7L 4.30:1 (Sold)
Others: 1982 F-250HD 4x2 RCLB 6.9L-IDI // 1988 F-250HD 4x4 SCLB 7.3L-IDI // 1995 F-350HD DRW 4x2 CCLB 7.3L-T444E PSD // 2004 F-350SD SRW 4x4 CCLB 6.0L-VT365 PSD.
VIN details are accurate for the linked truck only, YMMV.
TRENT310 is offline
post #3 of 8 Old 07-29-2013, 09:27 AM
Is it full to brim? Might need to run it for 10-20 seconds to get air bubbles out. Mine works great!
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
post #4 of 8 Old 07-30-2013, 07:05 PM
rexrus's Avatar
X2 If you figure it out, post your fix.
Sent from AutoGuide.com App
rexrus is offline
post #5 of 8 Old 08-09-2013, 05:46 AM Thread Starter
they wont replace the pump. said its normal for it to be like that. i don't think it is right at all.
post #6 of 8 Old 08-09-2013, 08:12 PM
On the C&C trucks, we have to replace the washer tuning and nozzles about once a year due to the underhood heat causing the little plastic "tee's" to dry out and crack/break..
Shoulda knows it was going to be a common issue when the dealership had all the parts in stock to fix it!!
poormanscat is offline
post #7 of 8 Old 08-11-2013, 02:44 PM
DSL_PWR's Avatar
Quoted: 9 Post(s)
Has to do with evaporation of fluid from the lines from the heat under the hood. Ford knows about the issue but at this time it is normal and the washers work as they should when fluid returns to the lines.
DSL_PWR is offline
post #8 of 8 Old 08-11-2013, 06:49 PM
Mine doesn't do that. I used mine today and haven't for maybe 3 weeks. Only had to wait like 2 seconds.
2011 F-350 CCSB
powerstroke43 is offline
