Track bar vs relocation bracket - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 16 Old 07-27-2013, 04:07 AM Thread Starter
Do they accomplish the same thing? Still undecided on brand of level kit to go with, but trying to determine if i just get a new track bar or if the relocation bracket accomplishes the same thing.
Readylift offers a relocation bracket, but i'm also considering carli or icon with new track bar.
Not trying to start a new which level kit thread, but trying to figure out if a track bar relocation bracket does the same thing as a new track bar. If it does, why would I want a new track bar as some kits offer?
input?
Tcm5080 is offline
post #2 of 16 Old 07-27-2013, 06:07 AM
WoodBoy's Avatar
It pretty much does. I would rather have an adjustable track bar than a relocation bracket.
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
http://www.powerstroke.org/forum/6-7...ustration.html
http://www.powerstroke.org/forum/6-7...round-2-a.html
WoodBoy is offline
post #3 of 16 Old 07-27-2013, 07:58 AM
If you are going to relocate you need a drop pitman arm too.
2012 F350, 6.7L Diesel, 4x4, SRW, Crew Cab, Short Box, Loaded, Ingot Silver
Detroit Truetrac, Icon leveling springs, steering damper mounts, King reservoir shocks and steering damper, Ultra Predator 22x10 and Nitto Terra 325/50R22 (35"s), H&S Minimaxx & Gearhead, aFe 5" SS w/ muffler, Leer XL, LineX, Titan 50gal, Airlift bags and wireless.
TrickTruck is offline
post #4 of 16 Old 07-27-2013, 09:00 AM
I always though all you needed for a level kit is a adjustable track or drop bracket. A new pitman is only needed with bigger lifts.
jordan572 is offline
post #5 of 16 Old 07-27-2013, 09:02 AM
With an adjustable track bar, the geometry stays lined up as it should - it needs to be longer which it will be with adjustment, but it's pivot points remain the same. If you use a drop bracket for the stock track bar and drop it's pivot points then you'll get bad bump steer if you don't drop the pitman arm pivot points too.
post #6 of 16 Old 07-27-2013, 09:06 AM
broncojason's Avatar
Ideally it is best to keep your drag-link and track bar parallel; keeping this geometry helps with bump-steer. With just a leveling kit, I don't feel that a drop pitman arm is a must with the track bar bracket, although in larger lifts, I would recommend it. So in my opinion, the adjustable track bar is best, but the bracket sold in the Readylift kit will suffice, while saving a lot of money.
2012 F250, Tuxedo Black, CCSB, 3.31, Banks Automind, leveled, Nitto Trail Grapplers.
broncojason is offline
post #7 of 16 Old 07-27-2013, 10:59 AM
But with a longer trac bar would you not have more axle shift during compression?
2006 Ford Powerstroke Super Cab 4x4 auto 120K bulletproofed
ramz trk is offline
post #8 of 16 Old 07-27-2013, 11:04 AM
The longer track bar is just to center the axle back under the truck. Without it, the axle will be shifted towards the driver's side approximately .75". Your axle will still shift/compress the same with or without the adjustable track bar.
post #9 of 16 Old 07-27-2013, 11:18 AM
c69ss396's Avatar
right on the money, Do it right, Bump steer sucks!
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #10 of 16 Old 07-27-2013, 11:20 AM Thread Starter
J,
With the relocation bracket, the axle will also be centered under the truck, correct?
Tcm5080 is offline
