Regen - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 4 Old 07-26-2013, 05:50 PM Thread Starter
Regen
I have gotten a lot of information from this forum. know I need some info. I have a 2011 F-350, 39000 miles. When it goes into regen the engine spits and sputters. Any one else have this problem.
clsalmonson is offline
post #2 of 4 Old 07-26-2013, 06:13 PM
"Stroker 8"'s Avatar
Quoted: 3 Post(s)
I personally have not, but there are folks on here experiencing the same issue who might chime in.
BTW,
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #3 of 4 Old 07-26-2013, 10:04 PM
Quoted: 5 Post(s)
research TSB 13-5-17:
ISSUE:
Some 2011-2013 F-Super Duty pickup vehicles equipped with a 6.7L diesel engine may exhibit a runs rough/misfire condition only during the exhaust regeneration process. This condition typically occurs on light throttle tip in between 64-113 Km/h (40-70 MPH), and will not set diagnostic trouble codes (DTCs). The concern may be intermittent and a knocking noise may be present during the concern.
2013 F350 Lariat Ultimate FX4 CC LB SRW
jetskier is offline
post #4 of 4 Old 07-28-2013, 07:28 AM Thread Starter
Thanks for the info jetskier. I think I am going to have to take it into the dealer this week. Thanks again for the info.
