About the 6.7 - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-25-2013, 10:28 AM Thread Starter
About the 6.7
okay guys don't have a lot of time to do the research so I'm hoping you guys can help me out. I'm trading in my 6.0 on a new truck this weekend got it narrowed down to a 2012 f250 6.7 it has 48k on it plus an extended powertrain warranty good until 90k.
my worry is that I don't know a lot about the 6.7 if they have any issues what I need to look for I don't want another 6 uhoh. want a reliable ride for my family.
are there a lot of issues with the 6.7?
what common issues if any should I watch for listen for Ect?
sorry I usually do all my own research but I'm pretty much in business meetings until Saturday and this Dealer is willing to give me 5k more than anybody else for my trade so I need to jump as soon as possible.
thanks for all your help in advance!
06 F350 ccsb zf6 Fx4 /Arp suds, egr delete, bpd hd oil cooler, swamps 58v FICM,5in turbo back str8, php ficm tunner w/egt probe, sct x3, bpd cac tube, diy regulated return, 6.4 banjos,ccv mod, zoodad, smoke switch, high idle, fan clutch switch, madmod, diy mesh grill, updated stc fitting ,stand pipes,dummy plugs
03 F250 stock but about to be torn down soon as i get time.
Nightwolf881030 is offline
post #2 of 7 Old 07-25-2013, 10:43 AM
The only issue I've experienced with my 2012 F-350 was in the transmission. The front pump would leak down while parked overnight and then would hesitate when I put it in gear the following morning. Dealership replaced front pump under warranty and no more issues.
2012 F-350 Crew Cab Lariat 4X4
H&S XRT Pro; DPF deleted; S&B Air Intake
2006 F-350 Crew Cab XLT 4X4 *SOLD*
hmdavid is offline
post #3 of 7 Old 07-25-2013, 10:54 AM
Crazyfrog's Avatar
Your not going to find the problems with the 6.7 like the 6.0 or 6.4 had. There are a few issues with the DEF throwing a code, but most have been a bad sensor. Some have experience tranny issues, and some have blown turbos. Most were '11 trucks.
Have you looked at new? There are some good deals to be had out there. A lot of guys have been 10k off sticker, and you would have the full warranty.
FYI, I drove mine for 20,000 miles, then deleted. Never had an issue at all.
2012 CCSB 4X4
XLT - 3:55 6.7
Mini Max-S&B intake
305/65/18 Falkens
Weather guard toolbox
Crazyfrog is offline
post #4 of 7 Old 07-25-2013, 11:35 AM
daystrom's Avatar
Quoted: 2 Post(s)
Radiators tend to leak where the plastic tank crimps to the core. Just had mine replaced (thankfully under warranty). Seems to be an old problem that won't go away.
2012 F-350 Lariat 4x4 6.7 PSD
Platinum metallic / adobe accent
"Sir Topham Hatt thinks I need to learn. He is mistaken. We Diesels don't need to learn, we know everything. We come to a yard and improve it. We are revolutionary!"
daystrom is offline
post #5 of 7 Old 07-25-2013, 03:13 PM
2013F250Tank's Avatar
If you're getting a warranyt till 90,000 miles you have nothing to worry all bugs will work out by then. there is a TSB on the trans pump to be replaced.
13 F250 Lariat CC SB 3.31 EL axle w/SPE full lock module, Ultimate Interior,
H&S Big Single 64mm NON VGT Turbo Kit, Cast manifolds, NON Cobra downpipe, Mini MAxx w/H&S stock fuel tune
Down Pipe back 304T 4" Diamond Eye, AFE stage II intake, front 4 link,
Road Armor bumpers front/rear. N Fab nerf steps. 20" American Force w/Trxus 33",
Dura flaps, Air Lift rear bags, 34k+ miles, Stage 3 traction block bars.
2012 F250 TOTALED.
Civilian Contractor Airforce 2+ years Asscrackistan.
2013F250Tank is offline
post #6 of 7 Old 07-25-2013, 03:43 PM
Quoted: 11 Post(s)
90,000 on mine. And I work it hard. Probably half of that mileage is towing 10,000 to 13,000 lbs, and really no problems to speak off.
Developed death wobble around 36,000 miles. Ford replaced front stabilizer shock. Seems to be a common problem with all the Ford 4x4 for the past 10 years. Brakes are a 70,000- 80,000 mile part. There have been a few frozen calipers. When you have the wheels off put some grease on the caliper slide occasionally.
As mention there have been few sensor issues with the emission system. The sensor will shut the truck down on the side of the road because it is reporting excessive exhaust temps. Fairly easy to fix, but dealers are not stocking the sensors. So it might take a day or two to get the part in. Frustrating if it's your truck that won't start.
There have been a few report sensor problems with their DEF tanks, Again it pretty well prevents you from driving until that sensor is replaced. It seems a few repair shops throw parts at this and replace the whole DEF tank, pump etc. But it most often is just a sensor.
The several dealers I've talked to have expressed concerns that all their in shop work is being done on 6.0 and 6.4 engines and since most of those are out of warranty, their hours have dropped off considerable. They are just not seeing a lot of warranty work on the 6.7L
2015 F350 CC SRW LWB Lariat, Leveled, BAKflip, Ultra Predator wheels with Toyo A/T 295/65R20, Firestone Airbags and onboard compressor
2011 F350 CC SRW LWB Lariat - Gone
Painted Horse is offline
post #7 of 7 Old 07-25-2013, 04:34 PM
Smoke Eater
Feedback Score: 5 reviews
Send a message via Yahoo to fdchief
Never had an issue with my 6.7... but im back in a 6.ohhh... i just love driving the ole 6.0hsss...
2007 F-250 Lariat Crew Cab
SPL LED Lightbar
20" Fuel Rims
35" Nitto MT's
SCT Livewire w/ Tony Wildman Tunes
PMM Full EGR Delete/ Coolant Kit
Hornblasters 540 Kit
LED Lightiing All Around
All kinds of other Goodies!
2005 Lariat Crew- GONE!
2011 Lariat Ultimate Crew- GONE!!!
Back in a 6.0hhhhh and lovin it!
fdchief is offline
