Questions about cold weather - Ford Powerstroke Diesel Forum
post #1 of 15 Old 07-22-2013, 07:44 PM Thread Starter
I_AM_RP3's Avatar
I bought a 13 F250 lariat in Virginia and recently moved to Connecticut. Because I got it down there it doesn't have a block heater. I've done some searching on here and reading about them but I don't know if I need one?!?! Should I bother with installing one? I read that most folks use full synthetic 5W-40 and some sort of anti-gel cetane booster like Opti-Lube XPD or Motorcraft PM-23 and 22.
Should I switch to synthetic and run the fuel treatment and let it be?
Can I switch to synthetic at such low miles? (2700 on the clock now)
Or should I get and install the block heater? Is it a hard job?
I_AM_RP3 is offline
post #2 of 15 Old 07-22-2013, 09:17 PM
BIG Laing's Avatar
I believe people who do not have a block heater, that wanted one found it easier to install some other means of heating the oil/block. I can't remember for sure, but it seems like someone installed an oil pan heater.
I will try and find the thread for you.
BTW these trucks don't have issues in the cold until we are talking under -20* F.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #3 of 15 Old 07-22-2013, 10:15 PM
Randy_270's Avatar
Quoted: 2 Post(s)
My truck started in -50C (-58F) weather without being plugged in all night, it actually started easier that my girlfriends car that was plugged in and started easier that my gas work truck. I personally wouldn't switch to synthetic until you have atleast 9000ish miles on it. IMO the conventional oil will do fine for now.
2011 F350 Lariat FX4, CCSB, 6.7, 3.55s, 325/65R18 Duratracs, Carli 4.5" Pintop, Flo-Pro, S&B intake, H&S w/ SPE tuning.
2011 Explorer Limited 4WD on 17x7.5s Core Racing Diablo 2s with 245/70R17 Duratracs
Randy_270 is offline
post #4 of 15 Old 07-23-2013, 05:01 AM
Quoted: 11 Post(s)
I have frequently left my truck outside at -25F and just touch the remote start and it fires right up. I did change over to Shell T-6 Synthetic for the colder months
I used to tease the guy next store. I'd hear him out cranking his 7.3L and running his battery dead and I'd remote start looking out the window.
2015 F350 CC SRW LWB Lariat, Leveled, BAKflip, Ultra Predator wheels with Toyo A/T 295/65R20, Firestone Airbags and onboard compressor
2011 F350 CC SRW LWB Lariat - Gone
Painted Horse is offline
post #5 of 15 Old 07-23-2013, 06:51 AM
RAINEY's Avatar
Don't they all come with the block heater installed? I think you just need to buy the electric plug in cord.
Jason
2012 F350 SRW Bought new with 550 miles on it in July 2013
RAINEY is offline
post #6 of 15 Old 07-23-2013, 06:55 AM Thread Starter
I_AM_RP3's Avatar
I read that somewhere but I looked above the starter which is where the org said it should be and all I have is a freeze plug with a big Allen head.
I_AM_RP3 is offline
post #7 of 15 Old 07-23-2013, 09:49 AM
Quoted: 11 Post(s)
The old powerstrokes built by international came with the element already installed and you just added the cord,. But not the new 6.7L Ford built engines.
Only the trucks shipped to the 14 northern states come with it installed. All other states just get the freeze plug on the engine block
post #8 of 15 Old 07-23-2013, 11:19 AM
TX_TRU_STUD's Avatar
Quoted: 41 Post(s)
per the manual/bible, all trucks come with this. You just need to add the plug.
TX_TRU_STUD is offline
post #9 of 15 Old 07-23-2013, 11:20 AM
Quoted: 41 Post(s)
mine has it and i am in TX....
post #10 of 15 Old 07-23-2013, 11:57 AM
Hellobatman's Avatar
I'm in Houston and have block heater and plug. Not like it freezes much down here....
2013 F-250 Lariat FX4, 6.7 Scorpion, All the bells and whistles!
Hellobatman is offline
