Need coolant test strips - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-16-2013, 04:08 PM Thread Starter
I know that a lot of guys on here have already tested their coolant. From what I understand the strips only last two years and you get many more then you could ever need in that time. My question is does anyone have some of the strips needed to check that they would like to sell? I am hesitant to spend $50 on a bunch of strips when I know that I would only use 8 or so before they expired. Thanks
joeycoates is offline
post #2 of 3 Old 07-16-2013, 04:15 PM
Quoted: 13 Post(s)
Doesn't work that way.
Not only are there 10 test strips in a kit. But the small vials that you place the coolant in for the test.
From the Coolant test instructions
If RA is low ( orangish color) add 5 ml of the coolant to the vial with the orange cap, using the syringe to accurately measure the coolant. If the RA us high ( greenish to green) add 5 ml of the coolant to the vial with the clear cap using the syringe to accurately measure the coolant Apparently there is something in the vials that modifies the test based on the RA.
You could buy the extra test strips, but you only have one set of vials in the test kit, So the person selling you the extras would probably keep his vials.
Your best option is to find a buddy with a 6.7L and share a test kit where both of you can use the same vials.
2015 F350 CC SRW LWB Lariat, Leveled, BAKflip, Ultra Predator wheels with Toyo A/T 295/65R20, Firestone Airbags and onboard compressor
2011 F350 CC SRW LWB Lariat - Gone
Painted Horse is offline
post #3 of 3 Old 07-16-2013, 05:20 PM Thread Starter
Good to know, thanks
