Help me make up my Mind - Ford Powerstroke Diesel Forum
post #1 of 15 Old 07-14-2013, 07:06 AM Thread Starter
99PSD-White's Avatar
Power stroke brothers, help convince me to get into another diesel. I traded in my 99 F350 CCLB 7.3L 2 years ago for my current 2011 Ford F150 fx4 ecoboost. I love the ecoboost. Especially with the livernois tuner. Im currently getting 16mpg with it and 5000 Miles away from being out of the 36k mile warranty. The ecoboost is fully loaded but Ive been wanting to get into another diesel! So right now my dealer is letting me test drive a white 2013 F350 crew cab short bed lariat 4x4 base model except for a few options. Here are my concerns. #1 it wont fit in my garage and my f150 does which is nice since I live in the Midwest and big storms are unpredictable. Also it wont come with heated and cooled seats as my f150 does. I dont tow very much any more and my commute to work is 13 miles. The f350 is $90 more per month including insurance. HELP!!!!!!
2013 F250 Lariat 4x4 Loaded. H&S mini maxx, 5" exhaust, S&B intake, and EGR delete, AMP steps, tonneau cover
2011 F150 Ecoboost FX4 Screw. All stock except for a livernois Tuner. SOLD!
Early 99 CCLB Pro comp 6.5" lift w 18" hulk wheels wrapped in 37" KM2s, Amp steps, Straight pipe, AIS intake, Dp Tuner, isspro gauges (boost,trans,pyro), 05 front clip, traction bars, 6.0L trans cooler, built trans.SOLD!!
99PSD-White is offline
post #2 of 15 Old 07-14-2013, 07:10 AM
If you don't use your truck much for towing anymore I'd probably stick with the F-150 especially if you would be loosing options on the truck. I live in Wisconsin and wish my truck fit in the garage
Tjmaxx is offline
post #3 of 15 Old 07-14-2013, 08:46 AM
broncojason's Avatar
I traded in my loaded 2010 F150 for my not so loaded F250 and absolutely love it. There are a couple options that I miss from the F150, but I have no regrets. I probably have more truck than I actually need, as the F150 was able to tow everything I needed, but I'd do it all over again.
2012 F250, Tuxedo Black, CCSB, 3.31, Banks Automind, leveled, Nitto Trail Grapplers.
broncojason is offline
post #4 of 15 Old 07-14-2013, 09:17 AM
"Stroker 8"'s Avatar
Quoted: 3 Post(s)
Trade the ecoboost but not for the white one. Shop around and find one fully loaded, there are a lot of good deals right now on '13s.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #5 of 15 Old 07-14-2013, 09:38 AM Thread Starter
I cant get a black one but it has the chrome package.....
post #6 of 15 Old 07-15-2013, 04:49 AM
Quoted: 3 Post(s)
Keep shopping, there out there with some incredible deals right now.
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
post #7 of 15 Old 07-15-2013, 04:59 AM
MyTractorsSexy's Avatar
Quoted: 3 Post(s)
do what he said not to mention id think you could do way better than 16 MPG... that would make up your 90 dollar a month difference
07 F250 Lariat ECSB bed FX4 6.0
leveling kit
XD Strike 17x9 -24 offset 295/70/17 Hankook ATm
HID's
fox shocks & fox dual steering stabilizer kit
K&N CAI
4in. turbo back straight pipe
ARP head studs
EGR delete
SCT Livewire custom tuned
sinister diesel coolant filter kit
blue spring
6.4 Banjo Bolts
BPD 48v FICM
Alpine double din
4 Hertz door speakers
2 rockford fosgate 10's
kenwood amps.
More pics in profile.
MyTractorsSexy is offline
post #8 of 15 Old 07-15-2013, 06:18 AM
Not sure where you're from, but there's a Ford dealer where I bought mine that still has three 2012s left, and they've got some smoking deals on them.
post #9 of 15 Old 07-15-2013, 09:34 AM
Your F150 Ecoboost sounds like the ideal pick up for your situation. The diesel will haul more, tow more; but if not used for hard work, it is not worth the $8000 extra cost, higher fuel costs, likely lower mileage, and higher maintenance costs. Diesels are expensive. You gotta justify them with the work needing done.
I got mine because I "wanted it". I didn't need it. I works great for towing my camper, but a F150 would likely do the job.
You're not wrong either way. One justs costs more than the other.
2013 F350 CC 6.7 4x4 Lariat 3.31
Black, Leer Cap, 18" Wheels
Grandpa's Camper Puller
dbj216 is offline
post #10 of 15 Old 07-15-2013, 02:19 PM
Id keep the Ecoboost
Jason1Pa is offline
