do they make oil filter guard??? - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 9 Old 07-06-2013, 08:53 PM Thread Starter
raftdaddy's Avatar
I still cant belive the oil filter location!! after reading one of the threads about the guy loosing an engine due to a stick freaks me out. what is the best product to protect it? I do allot of gravel and back roads hunting and I can see this being the Achilles heel on this truck.
2012 f350 lariat,35x12.50x20 on moto metal mo962 in 20x9 with o offset.bil 5100's,readylift 2.5 level
raftdaddy is offline
post #2 of 9 Old 07-06-2013, 08:58 PM
nohsp4u's Avatar
Well, if they don't, there is you once in a life time chance to get rich.
1997 F-350 XLT Lariat Crewcab long box 4x4. Oxford white with an ugly green. 133xxx miles. Hide away goose neck, banks turbo, exhaust, inner cooler, intake filter and gauges.
nohsp4u is offline
post #3 of 9 Old 07-06-2013, 09:06 PM
66Bronco's Avatar
I'd look into a remote mount kit before i looked into a guard.
'95 F-250HD
ZF 5-Speed 13'' clutch w/ SMF conversion
B&W Gooseneck
Custom Spare Tire Mount
66Bronco is offline
post #4 of 9 Old 07-06-2013, 09:11 PM
ZMANN's Avatar
Quoted: 245 Post(s)
I have seen 1 guard but it was a ridiculous plate
and $$
Just because I have a banner that states "Moderator"
does not mean you can't argue with my opinions !
ZMANN is offline
post #5 of 9 Old 07-07-2013, 05:46 AM
RAINEY's Avatar
I was thinking the same thing. Didn't really notice the location until I had my 1st oil change last week. The white Motorcraft filter stood out and made it more obvious. I don't do off roading or much gravel travel. I could see a road hazard taking it out.
Jason
RAINEY is offline
post #6 of 9 Old 07-07-2013, 07:38 PM Thread Starter
raftdaddy's Avatar
the first time I had seen it was when I put my 35's on and there is a wire on the side of that long bar your tire rubs on at full lock (ladder bar?) anyway my tire c aught it and pulled it off then 4 inches away is a giant filter. man what a stupid location. i'm still trying to get over not having an oil pressure guage!! and I did think of a remote filter kit but you know ford,if you have any problem they will say that it is a restriction in the oil system that caused it!! well I guess my inner MacGyver will have to come out
post #7 of 9 Old 07-07-2013, 11:51 PM
the 6.9/7.3L was underneath like that just on the opposite side....they were never really an issue.
The fuel filter housing on the other hand is ridiculous....it hangs below the effin frame.
1991 Ranger - 38" TSL's, 3 link, One tons, 5.38s on King air shocks....under construction.
1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 31x10.50r15 MT's.
2008 F350 - Crewcab short bed, 6.4L diesel, H&S XRT Pro, AFE DOC/DPF delete
1972 Mustang Coupe - 302, c4, 9", 4.11's locked.
WildStyle is offline
post #8 of 9 Old 07-08-2013, 12:00 AM
Quoted: 23 Post(s)
just get a permacool adapter, and run your own lines, should work assuming it is a spin on filter,
just get the specs for the factory oil filter, thread size. etc..
goes in place of filter
remote mount
then just run high pressure lines,
example of one mounted
jegs/ summit racing sells them, some people use them to run it threw a cooler before the filter
2002 F250 7.3/JW Tow master 4r100 190k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range , 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #9 of 9 Old 07-08-2013, 03:17 PM
brews4me's Avatar
I would imagine the fuel filter hangs there so it can be accessed and drained easily when the WIF light pops on? But cheap plastic and location seem bad!
brews4me is offline
