What tires on stock 18s? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-05-2013, 01:09 PM Thread Starter
brendan.9's Avatar
Hey guys have a 13 lariat f350 has fender flares on it and the stock tires and 18" rims, how big of a tire can i put on the stock rims? and whats some nice looking tires that will last also.
2013 F350 5" straight exhaust, Mini Maxx, CAI, H&S egr delete
03 SVT Cobra Whippled 632 rwhp 572rwtq Torch red 10th Anniversary coupe.
brendan.9 is offline
post #2 of 6 Old 07-05-2013, 01:21 PM
broncojason's Avatar
I'm running the 295/70/18 Nitto Trail Grapplers on my stock 18s and have plenty of clearance.
2012 F250, Tuxedo Black, CCSB, 3.31, Banks Automind, leveled, Nitto Trail Grapplers.
broncojason is offline
post #3 of 6 Old 07-05-2013, 02:17 PM
"Stroker 8"'s Avatar
Quoted: 3 Post(s)
Check out member Big Laing, he's got this setup on his rig and it looks great.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #4 of 6 Old 07-06-2013, 06:47 AM
Randy_270's Avatar
Quoted: 2 Post(s)
I'm getting 325/65r18s installed soon on stock 18s with stock suspension. I've even seen a truck with 325/60r20s on stock rims with stock suspension
2011 F350 Lariat FX4, CCSB, 6.7, 3.55s, 325/65R18 Duratracs, Carli 4.5" Pintop, Flo-Pro, S&B intake, H&S w/ SPE tuning.
2011 Explorer Limited 4WD on 17x7.5s Core Racing Diablo 2s with 245/70R17 Duratracs
Randy_270 is offline
post #5 of 6 Old 07-06-2013, 10:47 AM
BIG Laing's Avatar
Great choice ^^^. Bronco has Trail grapplers (MT) I have Terra grappler (AT)
I have 2 good friends running these tires also, both in AT's and MT's. One friend DJ got forced off the freeway in his '09 f350 with 35' 5er in tow by a semi. He went off the shoulder down an embankment and through 100 ft or so of a grass. All 4 295/70r18 trail grapplers were still mounted and fine. 5 of his 6 trailer tires dismounted.
I believe the quality tires (80 psi E rated but actually 129q load rated! That's over 4k lbs load rating per tire) possibly saved my friend his wife and 3 kids from a tragic ending that day.
Thanks Stroker 8
I have seen people putting wide tires like that on stock wheels too. IMO the manufacturer shows the approved wheel width for a reason. I would never tow or carry loved ones in a vehicle with an improper tire/wheel set-up.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #6 of 6 Old 07-07-2013, 05:14 AM
Randy_270's Avatar
Quoted: 2 Post(s)
I understand your concern for safety and I appreciate it. I will only be running this set up for a few months. Also I have no plans of towing or hauling anything more than 300-500 pounds while running the larger tires on the stock rim, just mostly highway driving. Also Im only going to be running them at 40-50psi max even though the tires are E rated and can handle 65psi.
